Severed fiber optic cables
I need to replace them and followed the line to the rear driver's side where there is an adapter that couples the fiber optic lines. I visited the dealer, gave them the VIN and took in the connecter from the audio gateway with the severed lines and the parts guy can't figure it out because it has no part # tag on it. Is this guy a moron (after speaking with him I don't doubt it) or does not know what he is doing?
He gave me the two adapters to connect the Fiber Optic cables but the cables must have a connector already on them in order to properly fit in the adapter to connect the lines. Since my cables are cut, they do not have the connecters to fit in the adapter. I just need fiber optic lines with the connectors already on them. Does anyone know the part # for just the fiber optic cables?
How long is the piece of fiber(s) you cut, connector to connector? It's a generic MB part used in most of the cars, just need to know how long to get you the right number.
I suspect the one you are looking for is A2114408406, MSRP $214.
The only difference a new factory cable will make is that it will have a connector on it but it is still fused with the above connector. I would say the heat shrink actually will be a more solid fuse of the two cables.
Yes, it could have been very expensive, but luckily it wasn't.
"Disadvantages:
• Fragile
• Repairs not possible without special
equipment"
Polishing the ends is an important aspect of any fiber optic cable termination, if you want to limit data loss to the accepted industry parameters at a given point of time for that technologies' evolution. Other repairs may seem to remedy the situation in individual instances, but you may be having loss to data of which you might not be aware, or the repair may not last in the long run.
Last edited by bosendorfer; Apr 22, 2012 at 12:05 AM. Reason: Took colon away after "pdf".
The price was less than $50us shipped and I do also recall seeing tons of sellers with cable by the foot when I searched. With more vehicles and other entertainment devices using fiber I'm sure the cost will continue to drop as more sellers become available.
http://www.aeromotive.us/
A friend of mine went to a trade show and told me about them -- I don't have any affiliation with them.
Regards,
paul...
