Best Brakes for the E350
I'm still trying to process his comments, so that I can make my own assessment but I do know a couple of things:
1) From my personal experience, I think that the ceramic pads stop just as well, if not better than the OE pads. This is in agreement with the comments of many forum users, as well as those of industry pundits that I've read on line, which leads me to believe that the ceramics are a good option.
2) I have no experience with examining the degree of rotor damage done by ceramics versus that of the very soft and dusty, OE pads. This is the big unknown to me.
Is there anyone out there who can offer some insight?
...have you seen more rapid rotor wear caused by ceramics?
Obviously this would cause future brake maintenance to be exponentially expensive, so I'd like to avoid that eventuality if at all possible.
To somehow believe the hype from a small aftermarket firm that they can do better seems questionable. If these pads were the best, Mercedes would likely be fitting them.
In addition, let's all give humanity some credit by remembering that the ultimate achievements are associated with advanced education. Some "survey" at somebody's website is meaningless in the face of actual engineering testing, and the place where the best engineers are is not doing website surveys and is not working at small, aftermarket "marketing" companies.
Don't worry about rotor wear--in the 21st century it's one set of rotors per one set of pads anyway.
The stopping power of the e-class is almost too good (have to think about who is behind you at times)
If you want to try another set of pads, I'd look at the Pagid Reds (Pagid is an OEM to BMW) - less dust but not that different from OEMs. Also replacing brake pads is one of the easier DIYs out there if you want to try.
My E550 has more than enough brakes to stop safely so to loose alittle for ALOT less brake dust...I think thats a fair trade off.
Everybody is entitle to his/her own opinions
However, let's say your doing 50MPH and have to hit the brakes (full on) in a hurry (and for the sake of argument lets assume you can stop quicker with the softer OEM pads) even if it's just 5 or 10 feet!.... do you want that extra safety margin?....... I do
My parents 06 E350 is due for brakes at about 50k miles. The front rotors are HEAVILY worn, the wear surface is a good 1+ mm under the original surface, and they feel very thin. My mom drives this car, mostly city, but still, the rotors shouldnt be this bad so early. So original semi-metallics - heavy wear, and tons and tons of dust.
I also have a 2003 BMW 540i and I recently did a brake job on it at 44k miles. All rotors were also worn and replaced, but the wear wasnt terrible. Still, decided to go ahead and do everything and not have to worry about it for another 40-50k. Again, semi-metallics - heavy wear, and plenty of dust.
On the BMW, I went with the original pads as some people complain about the Akebono ceramics lack of grip when cold. The E350 will be getting Akebonos though, the dust has been terrible and the severe rotor wear is ridiculous.
Rotors were $310 shipped all four, pads were $140 shipped.
Installed them in my opinion i have better braking power but thats just me, plus no brake dust.
Year later i am still happy customer with my setup.
