E-Class (W211) 2003-2009
Have to Replace Rotors Each Time?
Old Jan 18, 2011 | 07:55 PM
Fractal's Avatar
2007 E350
Question Have to Replace Rotors Each Time?
I went to a mechanic I normally trust because my 2007 E350 was displaying the "Brakepad Wear" message. He said I needed new breakpads and rotors. When I asked if he could resurface the rotors, he said no because MB's rotors are slightly curved so resurfacing them is really hard if not impossible. Is that true?
He also said you pretty much have to replace the rotors each time you replace the breakpads because the rotors are so thin. Is that true?
Old Jan 18, 2011 | 08:33 PM
gaazmon's Avatar
2009 SL550 Roadster Diamond White, 2008 CLK550 Coupe Obsidian Black
ya i was told the MB rotors cannot be resurfaced either. i was told rotors should be changed every other break pad change
Old Jan 18, 2011 | 08:49 PM
Benz-O-Rama's Avatar
I've always been told the same as well. E-Class (Non-AMG) rotors are cheap, so it's not that big of an issue.
Old Jan 18, 2011 | 08:57 PM
06e320cdi's Avatar
2008 ML320CDI
If the rotors are still smooth and not scored, I can usually get 2 sets of pads from one set of rotors (OEM Pads of course). However you run the risk of squealing brakes, as most likely the rotors willl not be as smooth as new
Old Jan 19, 2011 | 07:27 AM
LOVEMYBS's Avatar
10 Cayenne GTS, 07 Porsche 911 Turbo
Your mechanic is wrong. You do not need to replace the rotors when you replace the pads. Buy a new set of Akebono brake pads and you should be fine for a lot less $$$$.
Old Jan 19, 2011 | 05:35 PM
vettdvr's Avatar
03 E500 and Corvette
Same here. My front rotors are origional from new with 102,000 miles and on pad set #3 (factory,dealer installed 1 and I installed 1). Next pad change will include new rotors.
I do however measure rotor thickness to verify it is within spec and has enough thickness to run the entire pad life.
I DON"T TURN THEM and MB DOES NOT RECOMMEND TURNING
