E-Class (W211) 2003-2009
Class Action suit over M272 M273
Old Mar 31, 2021 | 10:22 PM
  #276
09 W211 E350's Avatar
2009 W211 E350
Hi, I own a 2009 e350. I would like to make sure that it is not in the bad range of balance shaft problem.
VIN WDB2110561B372740
Engine 272964 31 021706
Car needs new intake manifold along with other wear and tear repairs.
I would like to be 100% sure it will not have a balance shaft issue before I further invest into it.
Any advice would be much appreciated.
Thank you.
Old Mar 31, 2021 | 11:23 PM
  #277
cetialpha5's Avatar
Thank you.
Balance shaft only affected all of 2006 and some early 2007 models. The 2008/2009 models should be fine.
Change oil breather cover and oil separator when doing the intake manifold.
Old Apr 1, 2021 | 02:11 AM
  #278
2009 W211 E350
Thank you for your response. So my understanding is that I am clear of the possibility of balance shaft problem, if I’m correct.
Yes I will have the entire breather cover kit changed at the same time including the oil separator when doing the manifold. I’m also planning on using the metal rod and lever repair kit with a new intake manifold to ensure it’s not gonna brake again. After that should I expect trouble free years out of the car with regular maintenance since it only has 77 000 miles?
How is longevity/reliability on these cars? Any other serious problems I should expect?
Old Apr 3, 2021 | 05:31 PM
  #279
N_Jay's Avatar
2019 WS222 S450 4-Matic / 2007 W211 E350 4Matic (Sold) / 2008 X164 GL320 CDI
177K Miles on our 2007.
Old Apr 3, 2021 | 06:08 PM
  #280
cetialpha5's Avatar
I wouldn't waste money on the metal rod/lever repair kit. Just get the intake from FCPEuro, they have a lifetime warranty on all the parts they sell. The lever breaking or the rods going tells you that the flaps are starting to get gummed up. If you replace those items so they don't break, the flaps will probably just break first and fall into the engine causing engine damage. I would just keep an eye on the breather cover/oil separator and change them as needed and you'll probably get at least another 80-120k or more out of the intake before it goes again.
Old Apr 3, 2021 | 10:46 PM
  #281
2009 W211 E350
Good point about the repair kit. Now I’m thinking about returning it and just replacing the manifold from Fcp euro.
How often should the breather cover set be replaced?
Old Oct 20, 2021 | 11:07 PM
  #282
gagan takker's Avatar
E 350
(VIN) WDB2110562B226351
Engine 272 964 30 731105
Is ahead of affected range 30 468993, Correct?
Old Oct 21, 2021 | 09:57 AM
  #283
konigstiger's Avatar
'71 Pinto
You're fine.
Old Oct 24, 2021 | 05:12 AM
  #284
E 350
You're fine.
I have a mechanic friend who can help me do preventive maintenances
Where can I find the steps or How to videos or DIY e.g Spark Plugs, Coolant. Differential oil etc
Old Oct 24, 2021 | 10:49 AM
  #285
'71 Pinto
Search ebay: "wis epc mercedes".
