Class Action suit over M272 M273
#77
Ok guys, I need help translating. The datacard on that russian link gives me two different engine related numbers. The first is this: engine 273962 30 059026
and the second one is: MTRSAC A2730102602.
According to Konigstiger's 2/18/11 Post, "M273 (550) up to 088611"
I'm wondering which one of these is the true serial number. Thanks again
#78
#82
2007 CLS 550 got the same failure
I just had the same problem. Timing Gear (Sprocket) failure with only 60K miles. Dealer quoted at least $4500. They gave me a number to call MB directly to complain and basically they blew me off and told me they would not do anything to help but asked me to contact dealer for some relief on the cost. I found a certified MB shop (not a dealership) to pull the motor and repair for $3100.
If anybody has gotten MB to help with costs please reply. Thanks
#84
Anyone able to assist in verifying my VIN # if this car is in the "bad" serial number range for the balance shaft gear failure?
WDDGF85X39F329034
Thank you
WDDGF85X39F329034
Thank you
#85
WDDGF85X39F329034
Thank you
WDDGF85X39F329034
Thank you
From Konigstiger's post #60 on a previous page:
272 engine up to Serial # 30 468993 or 273 engine up 30 088611 material for the balance shaft sprocket and the timing chain guide wheel (idler) was modified on engines past these serial #s.
#86
Cam #4 Misfire '06 e350
I had the MB Dealer repair this problem in Oct. 2011 and the check engine light came on and is throwing the same code. Does this have anything to do with the Defective Gears on the M272 engines?
My engine serial is 272964 30 100463 and appears to be within the problem window.
Any help would be appreciated.
#87
Hello
I have this benz with this VIN: 4JGBB86EX6A148398
i wonder if my vehicle is affected by this camshaft gear problem? THanks
#88
272 engines up to 30 468993 are affected and thus your engine is affected.
#89
#90
My VIN WDBUF90X87X212095. Am I affected? THANKS!
273 engines affected up 30 088611.
So yes you are.
Here's your car's datacard.
#91
Purchasing a W211 very soon
I am at the final stages of researching purchasing a W211 (either E350 or E500). Unfortunately, it would appear that all of the cars I am looking at have the possibility of being in the range of this issue.
I have tried unsuccessfully multiple times to subscribe to the Mercedes EPC online website to check the engine numbers of the vehicles I am looking at for this problem.
Can someone help me determine what the Engine numbers for the following cars are?
1. WDBUF70J85A672972 (2005 E500)
2. WDBUF70J96A942390 (2006 E500)
3. WDBUF56X17B032096 (2007 E350)
4. WDBUF56XX8B249681 (2008 E350)
Thank you very much in advance for your help.
#92
First: The E500 don't have the M273 engines, those would be the E550 (MY07 And Up).
3. 2007 E350
Engine Serial Number:272964 30 451670.
272 engines up to 30 468993 are affected and thus this engine is affected.
4. 2008 E350:
Engine Serial Number: 272964 30 774147
Engine not affected.
I attached the Datacards to help you see each car's options.
3. 2007 E350
4. 2008 E350:
#93
#94
#95
Hello Can you please run my vin number? Thank you in advance WDBUF87J86X199889 Tom
#96
2014 BMW M235i
Is the 2007 E550 affected? I haven't experienced any issues but so far in the page of the thread I've read it doesn't look like it's on the class action lawsuit. No conclusive answer if this MY is included from reading this thread so far so I'm a but confused, but I will post my VIN tomorrow so someone can run it if they so please. Thanks.
#97
#98
2014 BMW M235i
I'm well aware haha, it's pretty incredible that these two known issues have gone so far ignored. Thanks for the updates you've done on that issue on the other thread though, as well as that story you mentioned about a possible victim of SBC failure. Frightening to say the least.
#99
Engine Serial Number:272964 30 623565
272 engines up to 30 468993 are affected and thus this engine is NOT affected.
#100
E350 ML350 SL550 Cruisers 5000 Sedan Sport
PortAxePlayer1,
Would you be kind enough to look up the data Cards for my 2 350’s:
2008 E350 WDBUF87X98B323642
2010 ML350 4JGBB8GB4AA543741
