E-Class (W211) 2003-2009
No sound from alarm/beeps
Old Feb 19, 2011 | 09:40 PM
ttsidd's Avatar
2014 S550 4Matic
I no longer hear the car beep when locking/unlocking, and the panic alarm is silent as well...any ideas? I did have an issue with a wire harness that was replaced at the dealers but I have not heard the alarm since--check with them?
Old Feb 19, 2011 | 10:38 PM
Tjdehya's Avatar
2023 AMG EQS
The panic alarm is also silent? Then yes I would say that you should have it checked out.
Old Feb 20, 2011 | 05:02 AM
Gersh320's Avatar
E320 & X166
My car never beeps when locked or unlocked. It could be that you changed a setting somewhere.
As far as panic, I don't know. You can't turn that one off.
Old Feb 20, 2011 | 08:03 AM
Clinton Horn's Avatar
2003 E320
I belive the chirp for locking and unlocking is a selectable feature. As for the alarm, we recently had a issue where the car would not lock and the lights stayed on. The cause was eventually traced to the "siren". It is a pretty reasonable part. I would have put it on myself and saved the $299 labor but
a. The dealer had already suckered me by ordering a new key that was unnecessary
b. I did not know where the siren was located on the chasis.
c. It cost $385 to find out that the key was not the problem and $125 of that was applied to the siren labor.
I could never find the siren part number or a mailorder house that sold them. May be a dealer only part.
Old Feb 20, 2011 | 09:01 AM
konigstiger's Avatar
'71 Pinto
Available @ parts.com $108 + shipping
Old Feb 20, 2011 | 09:06 AM
GT-ER's Avatar
2005 E55 AMG
My siren died on me....where is it located?
Old Feb 20, 2011 | 09:44 AM
'71 Pinto
#80 in diagram you need to remove driver side rear inner fender. PM email address if you want replacement instructions.
File Type: pdf
Old Feb 20, 2011 | 12:57 PM
Mackhack's Avatar
It only beeps if one would set it deep in the system with SDS. I did enable the chirp sound on a bunch of cars here. It's nice to hear and see that the car is locked (mirrors fold in and blinker blinks of course).
The chrip comes from the alarm system's horn not the regular horn btw.
Old Nov 20, 2011 | 03:08 AM
AzCamel's Avatar
10 GLK350/ 15 Accord/ 94 Supra Turbo
do you have the direct link? i tried looking and non i found was 108.
Old Nov 20, 2011 | 09:19 AM
'71 Pinto
Check your email
Old Aug 18, 2022 | 11:00 AM
Muhtish's Avatar
2006 E55 AMG
Redirecting this topic
I have 2006 W211 E55.
One day, out of nowhere, my alarm quits working (no chirp) when locking or unlocking the car with a remote. Siren (panic button) is not working as well.
Car locked and unlocked with remote until this morning. Locked the car last night, morning comes, can't unlock the car with a remote (no flashing lights). Car does not respond to any buttons on a remote.
The red LED light flashes when buttons are pressed. Infrared sensor lights up when buttons are pressed (phone camera picks up infrared). Changed batteries=nothing changed. Unlocked the car with the key, it set off the alarm system (no sound though), hazards started flashing.
Why wouldn't remote work all of a sudden? Suggestions?
Anyone has fuse location/number that I should be checking?
Thank you!
Old Aug 19, 2022 | 06:16 PM
Muhtish's Avatar
2006 E55 AMG
update:
Connected my iCarSoft scanner and found a couple of codes:
Rear SAM:9077 Communication with component Radio signal reception of the central locking system interrupted
9059 Communication with component B33 (ATA inclination sensor) interrupted9078 communication with component H3 (alarm signal horn) interrupted
time to start digging around...
Old Aug 20, 2022 | 12:37 PM
'71 Pinto
Siren internal board known to corrode, start here.
File Type: pdf
File Type: pdf
Old Aug 28, 2022 | 12:32 AM
Muhtish's Avatar
2006 E55 AMG
Update:
after hitting a few forums, I've decided to purchase a new alarm unit. Found one for $140 at a dealer. Opened up the drivers side front wheel well and located the old unit. After removing the old one, I was simply amazed at the stupid decision of putting a drain tube just an inch above and just slightly to the side of the electrical component. No wonder why these things go out! Water and electric parts don't belong together.
Installed the new unit. Ran an extension from the existing drain tube, so that it is draining BELOW the alarm. Secured it with a zip tie and now everything is better than from factory.
It is amazing to me how smart people can be so disconnected from functionality of the real world.
One thing left to do is to run the scanner and see what it says.
