Dead Battery - can't get into trunk
So my car has been sitting most of the winter, and the battery went dead. However, I can't seem to get into the trunk using the blade key... so is there a place under the hood that I can use to power up the car to unlock the trunk via the key fob?
Mercedes E55 AMG (2006), Mercedes 560 SEL (1991)
Common mistake. When you use te blade key, turn it counter clockwise, and try opening the trunk while STILL TURNING THE KEY. it will then open mechanically rather than electronicly
Just an update... blade key didn't work at all despite every which way I tried opening it. Found the positive terminal at the fuse box under the hood and applied some power and was able to pop the trunk with the remote. It's all good.
2007 E350 P1 Sport Pkg, 1993 BMW 325is, 2000 Tacoma PreRunner V6, 2008 Porsche Cayman S
