E-Class (W211) 2003-2009
Rear door panel removal
Old Mar 4, 2011 | 05:19 PM
juanchente2004's Avatar
2008 E350 Sport Pano Roof
Can somebody help me in some instructions on how remove the rear door panel on a 08 W211...
Old Mar 19, 2011 | 03:19 AM
Alps's Avatar
E63s s213 2019 ,SOLD E63 Weistec, E55, C36
pretty easy
- take out rear ashtray unit, undo torq 30 under there.
- unplug the 2 x plugs from behind the ashtray for the lighting and switches (important you do this as most probably you will damage the ribbon for the lighting).
- pull off the panel below the handle to reveal 2 x torq 30, remove these.
- pull off SRS plastic cover, there will be another torq 30 under there.
- rest is held on by door clips and the panel should pull off
- you will have to unclip the door handle cable once the main panel s off.
job done, just be carefull of that ribbon cable about $45 to replace if you damageit.
