E-Class (W211) 2003-2009
Engine Mount
Old Mar 12, 2011 | 11:56 AM
Tom T's Avatar
2017 E300
Engine Mount
Hello all,
I changed the transmission mount at around 60K miles. Now my car is about 90K miles. I noticed that my car is not as smooth as it should be. There is some vibration at start up and I can feel and hear (more than normal) the transmission as I drive. I think it is time for the engine mounts.
Here are my questions.
1. What are the signs of the worn engine mounts?
2. Are there only 2 mounts (left/right) to replace, I read some where there is a 3rd one in the back of the engine, is it true?
3. Any recommendation for the brand of the mounts?
Thank you
-Tom
Old Mar 13, 2011 | 02:23 PM
MB:Specialist's Avatar
W211 E55, W211 E500 estate, A124 E320
-You know the engine mounts are bad when you start the vehicle and you feel/hear rumbling.
-You can put it on a lift and look at the mounts and most likely there will be a brownish fluid dripping onto your steering rack/subframe
-Buy O.E. , sachs, or bilstein mounts
-The "3rd" mount is the transmission mount you already replaced
Old Mar 13, 2011 | 03:29 PM
Tom T's Avatar
2017 E300
If that is the case then I think mine are still good. Thank you
Old Mar 14, 2011 | 04:26 PM
PlatinumPi4u's Avatar
06' w211 E500 Sport
Actually at about 80 or 90k is when the motor mounts go... mine has 86k ('06 e500) and all 3 are due...
Old Mar 14, 2011 | 08:53 PM
dsm2925's Avatar
W211
the car only has 2 mounts...
my mount was bad and i did see any brownish stuff on it although i drove my car over 15,000 after replacing
Old Mar 14, 2011 | 11:19 PM
GT-ER's Avatar
2005 E55 AMG
3 mounts. 2 for engine and 1 for tranny.
