E-Class (W211) 2003-2009
Spare Tire
Old Mar 28, 2011 | 06:03 PM
2slowcdi's Avatar
2006 E320 CDI 235 hp 420 ft tq
Spare Tire
I'm looking at getting a OEM wheel and putting in the trunk does anyone know if a 225 x 55 x16 will fit in the spare place with out taking up any more room?
The car is a 06 E320 CDI.
Thank You
Old Mar 28, 2011 | 08:59 PM
novae500's Avatar
W211
forget getting an OEM tire. I went to tirerack and found the closeouts and got an 18 OZ botticelli w/Conti DWS tire for $300 for both. Its full size and much better than a spare. The baseboard cover sticks up about 2inches higher w/the cover over it.
Old Mar 29, 2011 | 10:49 AM
lkchris's Avatar
'10 CL550, '12 GL550
OE tire with OE size wheel fits fine. BTDT.
You'll need to order a different holddown and remove the styrofoam under the minispare. The new holddown basket provides a nice storage opportunity.
eBay is a pretty good place to get a wheel, although you have to read carefully to assure the wheel offered isn't a "replica." Also confirm shipping is NOT by FedEx because if it is wheel WILL arrive bent.
Old Mar 29, 2011 | 11:13 AM
BenzboyW210's Avatar
2007 E550, 2007 GL450
Good to know, thanks for sharing. Having recently limped home on the stock spare after hitting a crater, er pothole, a full size replacement would have been nice.
Old Mar 29, 2011 | 11:16 AM
threeMBs's Avatar
Only MBs - the best or nothing
How is that possible?
Old Mar 29, 2011 | 12:02 PM
2slowcdi's Avatar
Thanks for the replies.
I found a place a few years ago and have used it for my Land Rover wheels and have never had any problems with the wheels.
They sell the OEM 16 x 8 for about $160 to my door.
Bigger wheels look nice but by the time you get the tire and wheel you have more weight spinning around with that its starts alot more needs.
I'm more of a gear head so I like something that looks stock.
Old Mar 29, 2011 | 10:17 PM
buffyclk500's Avatar
clk500
i have space saver rims and som 16in oem rims with tires if u need them
Old Mar 30, 2011 | 06:46 AM
2slowcdi's Avatar
Those are different than mine, but Thank You for the though !
Old Mar 30, 2011 | 09:30 AM
Barry45RPM's Avatar
2015 ML 350
Originally Posted by BenzboyW210
...Having recently limped home on the stock spare after hitting a crater, er pothole, a full size replacement would have been nice.
Bear in mind that with a mini spare, you don't have to jack up the car as high as you would if you were putting on a full size, fully inflated tire. (which you will then have to take the extra time to jack higher than the bottom flattened tire that you just dropped off the car. You will have to jack the car higher up to line up the wheel bolt holes with the holes on the car than you will with the smaller spare tire.) Also, the mini is lighter and easier to heft around while you're lining up the holes. Therefore, you will be done quicker with the job, & out of harms way sooner and back in your car, on your way.
...That's assuming YOU are changing the tire with the tiny scissor jack and hand tools, on the side of the road rather than a long handled Heavy Duty garage/service truck jack and power tools for the lug bolts that a Road Service guy will bring to the party..
Old Mar 30, 2011 | 01:17 PM
2slowcdi's Avatar
I have not looked but I would think that a mini spare can not be driven at highway speeds safely, and the mini spare is just for temporary use.
Old Mar 30, 2011 | 07:41 PM
Barry45RPM's Avatar
2015 ML 350
I'd say 50MPH for a total of 100 miles.
Old Mar 31, 2011 | 08:00 AM
2slowcdi's Avatar
That is about what I though.
Old Mar 31, 2011 | 11:00 AM
lkchris's Avatar
I'd rethink this.
The minispare HAS to be the same rolling diameter as the original tire to avoid complications with the differential(s).
Now on a jacked-up car the wheel may go in at an angle and the narrower width could help, but I'd think it's pretty minor.
When I've rotated tires using the mini as a placeholder I can't recall needing to add more height to get the normal tire mounted.
Old Mar 31, 2011 | 04:37 PM
Barry45RPM's Avatar
2015 ML 350
I'd rethink this.
I'd say they're similar, but notice any car with one of them mounted on an axle... The car always is "kneeling" in that corner.
