E-Class (W211) 2003-2009
05 e500 windshield fogging problem?
Old Apr 1, 2011 | 11:11 PM
redbeard999's Avatar
2005 mercedes e500
for some reason when i drive with all the windows up the back windshield and back windows begin to fog BADLY. the only way i can get it to stop is by cracking the windows. even the defogging button does not do much. what could the issue be? its really irritating. please let me know. and no, i am not a heavy mouth breather.
Old Apr 2, 2011 | 09:15 AM
RA72825's Avatar
Can you confirm good air flow through the center console rear vent and the door pillar vents to the back? They are wide open?
Old Apr 2, 2011 | 09:38 AM
vinceleo's Avatar
E450
are you sure it isn't stuck on "recirc"?
Old Apr 2, 2011 | 12:17 PM
2005 mercedes e500
the vents work fine and are open, but i usually have the climate control off because i never need heat or AC. which button is the recirc butto?
Old Apr 2, 2011 | 12:54 PM
vinceleo's Avatar
E450
it's on the left side of the controls - the top half is the max defrost and the bottom half of the switch is the recirculation button. With the recirc turned on, you don't get outside air and you pick up the moisture in the car. But if you are leaving the entire HVAC system turned off, my guess if you are getting air flow into the car from outside - not sure, just guessing???
You can just leave the system set to Auto and manually turn off the A/C if you don't want A/C and you still get fresh air without opening the windows.
Old Apr 2, 2011 | 01:14 PM
Mackhack's Avatar
Originally Posted by redbeard999
[...] which button is the recirc butto?
RTFM
Old Apr 2, 2011 | 01:41 PM
2005 mercedes e500
lol i actually had to google "what does rtfm mean" . but ya thanks. i guess ill just leave the whole system on auto. thanks bros
Old Apr 2, 2011 | 01:53 PM
Mackhack's Avatar
Hehe Sweet. Auto doesn't really help as it only keeps the car's temp. at the set temp. You still have to control the output direction though.
Old Apr 2, 2011 | 02:43 PM
2005 mercedes e500
i just want air coming from outside and coming in. instead of just recirculating the cabin air. that would fix it right?
Old Apr 2, 2011 | 02:46 PM
Mackhack's Avatar
I barely have fogged up windows here but when I do, I turn on windshield defrost for 5 seconds, turn it off and it's all done. It's the A/C that turns on and has dry cold air that takes care of it immediately.
Old Apr 2, 2011 | 02:50 PM
2005 mercedes e500
okay thanks. i will try that today if it gets bad. thanks bros
Old Apr 2, 2011 | 05:27 PM
vinceleo's Avatar
E450
My car is a 2008 E350 and I just played with the controls... mine resets the fan, temp and output direction when I hit Auto. For example, if manually set it to the floor, it goes where it thinks it should when I hit auto such as the middle vents.
Old Apr 2, 2011 | 05:40 PM
Mackhack's Avatar
As intended! It always changes to the middle ones on auto.
