Finished intake mods
Finished a few quick intake mods today. Saw these elsewhere on the board in the past and thought I'd try them out. Three easy ways to get more, colder air to the engine.
1. K&N filters
2. Thermo-tec heat shield on the bottom side of the airbox
3. Cut out the two inlet coverings just behind the front grille
I had the Powerchip ECU upgrade installed a few weeks ago, and Joel there said he has an upgrade to take advantage of the K&N's and my exhaust. I'll be taking it in next week to take advantage of that. For now, the car really screams. Will be taking to the Dyno once the upgraded Powerchip is done.
1. K&N filters
Various
Re: Finished intake mods
1. K&N filters
1. K&N filters
Re: Nice
[QUOTE]Originally posted by ADOLFO
[B]Where did u get the kit and how much?
Wasn't a set kit. I got the K&N filters from a local shop (most any auto parts store that carrys K&N's can order them if not in stock), then ordered the Thermo-tec heat shield material from www.speedzone24-7.com . The filters are about $50 ea. (you need two) and the heat shield material was about $40 with shipping (two 12" x 24" pieces). It actually was very easy to do. All the intake pieces simply "pop" off. Then a few torx screws need to be unscrewed to remove/install the new filters. The toughest part is adhereing the heat shield material to the bottom of the air box. Everything takes only about an hour, and all you need is a pair of scissors to cut the heat shield material and a torx screwdriver to install the filters. If you do it, I recommend getting the heat shield material that has the self-adhesive backing.
3M makes a tape expressly for heat insulation. it is a foil/glass cloth w/ adhesive backing.. problem is it is about $95 a roll..
A roll is 1" x 108 feet.. according to my calculations.. that is about 9 square feet...
If the previously mentioned product is 2 square feet for $18.. it seems as if the prices are pretty similar.
Regardless, here is the spec from 3m
3M™ High Temperature Aluminum Foil/Glass Cloth Tape 363,
1 in x 36 yd, 24 per case
Shiny Silver, 7.3 mil (.185 mm) aluminum foil/glass cloth tape that can be used as a high temperature, heat reflective, protective wrap for certain cables and other components in aerospace and industrial applications.
I havent driven the car yet - I installed about an hour ago, and I dont have anywhere to go yet
It was easy and it makes sense to keep the air cold going in. I like the way the wrapped intake pipes look with the shielding... More race-car looking.
