e550 sport 2003 questions!!
e500 sport 2003
e500 sport 2003 questions!!
hey guys,
just got a e500 2003, sport model with air suspension.
i got a couple of questions and fix to do,
first of all:
1. the needle of the speedometer is stock at 40 km/h.. what to do?
2. i need to change the armrest, cause the leather is *slack*, where to get a replacement at a cheap price..
3. the car has been sitting for a long time with no start, is it normal that the rear air suspension was all down... or there is some sort of leak?
thanks for the help
first of all:
thanks for the help
In regards to question 3. That is normal. The car will sit when its not being used. My old E class did the same. If you start it up. It should slowly jump back to normal stance.
ps. is this a e55? or e500? I have never heard of a 2003 e550
e500 sport 2003
yea the suspension went up when i stated the car, pretty cool lol
You're probably going to need a new instrument cluster. I don't think a stuck needle is repairable. I'm sure a dealer will want to replace it. Try calling an independent mechanic and see what they say.
As for the armrest, read this thread: https://mbworld.org/forums/e-class-w...aminating.html
Received 4,435 Likes
'71 Pinto
Open IC glass in an attempt to clean however, as mentioned may need to be replaced. This link is for CLS, same principle https://mbworld.org/forums/cls-coupe...placement.html
Airmatic needs to be leak tested check PM
