E-Class (W211) 2003-2009
Help Please!-- W211 E500 Lowering
Old Apr 6, 2016 | 02:31 PM
  #51
Agent-A01's Avatar
05 W211 E500, 03 C215 CL55 AMG
Originally Posted by karpetcm
sorry to bug saw this and wanted to do it as well. do i put washers in were the control arm is and by the sensor bracket in the rear?
4 on each control arm in the front and for the rear you get a 1/16in washer to use it as a shim for the rear.
You just loosen up the rear sensor's bolts enough to where you can put the 1/16 washer in.
Old Apr 6, 2016 | 03:21 PM
  #52
karpetcm's Avatar
2006 E55 AMG
I did this mod about a week ago and i know why some go towards lowering links. The fronts on my car barely fit 3 washers and even then it was rough trying to get the nut to catch threads very tough. The rears i lowered using the washer method as well but because i couldnt lower the front enough the rear sat too low and the rear washer was very thin. Also the passenger side rear sat lower. I think for 130 bucks im gonna do the lowering links although the ride height seems fine in the front because i left the 3 washers it could be lower. My rears are stock and i took the washers out.
