E-Class (W211) 2003-2009
code p0600 pour e320
Old Oct 31, 2011 | 10:17 AM
iulianpopa's Avatar
e 320
Hello,
can somebody help me with the code P0600
the car start normaly but not light on dash,
I drive the car without any probleme but not AC, heat, instrument cluster, not lights on dash, if I stop the car, and I restart everything is ok.
thanks for your time
Old Oct 31, 2011 | 02:53 PM
vettdvr's Avatar
03 E500 and Corvette
Originally Posted by iulianpopa
Hello,
Double check your battery cable and ground. Makes sure they are clean and secure. Don't guess by looking.
Old Nov 3, 2011 | 10:28 AM
iulianpopa's Avatar
e 320
I change the battery yesterday,
each morning I have the message "Switch off lights"
same this morning after the battery was changed, also after 2 minute 1 malfunction is coming ESP malfunction.
I drive the car for 30 minutes, after restart not error message, no malfunction for ESP
I check for error codes with the ODB tool and not error.
but each morning the same "Switch off lights"
Old May 2, 2012 | 12:11 PM
iulianpopa's Avatar
e 320
key issue
it was the key
when I use the second key everuthung is ok.
I bought the key outside case on Ebay, and it was ok for some weeks and after the it's something bad with the electronics parts inside.
Old Nov 6, 2018 | 04:01 PM
Amer Nagi's Avatar
2003 Mercedes E320
wow , i have the same exact issue . some say its a fuse or blown fuse . or it might the ECU . DONT KNOW .NO CLUE
