E-Class (W211) 2003-2009
Engine Mounts or Transmission?
Old Nov 5, 2011 | 11:46 PM
Tom T's Avatar
2017 E300
Hello all,
I have a 2004 E 320. I noticed that the car runs very rough when its cold. I can't tell weather the rough sounds coming from the transmission or the vibration of the engine. All I know after I have driven the car for awhile (20-30 minutes) it gets smoother.
Old Nov 6, 2011 | 02:57 AM
AzCamel's Avatar
10 GLK350/ 15 Accord/ 94 Supra Turbo
Sure way to tell if your mounts are out is to open your hood, put the car in drive and hold the brake and blip the throttle and see if the engine moves.
Also when my mounts were out it always vibrate at idle, if yours goes away it might be something else.
Old Nov 6, 2011 | 05:44 PM
djrabbi's Avatar
EQS AMG, E53 AMG, GLE63s
I replaced mine yesterday.....feels baby soft!
Old Nov 6, 2011 | 09:17 PM
Tom T's Avatar
2017 E300
Thank you for the reply. I did the engine mounts check (as AzCamel suggested) the engine move up about half an inch. I did the samething test with my 05 accord and get the same result. So this means that my engine mounts still good?
Old Nov 6, 2011 | 09:19 PM
djrabbi's Avatar
mounts are good than....mine were so bad that my engine would hit my hood lol..moved like 5inches up haha...Well if its only during cold, that should be normal!
Old Nov 7, 2011 | 02:01 AM
AzCamel's Avatar
mine would move up a few inches up and down, so your mounts sound fine and as i suggested that if it goes away it is most likely another problem. I recall reading about a internal balancer that goes bad in the six cylindar model so you might look for that thread.
