Secondary Air Injection Pump stays on
After getting home today, i noticed that there was this fan still running in the engine compartment after i turned off my car. It was the pump that sits right infront of the engine. I unplugged it and it stopped. My assumption is that's the SAIP. After searching google, it seems to be a bad relay. Does anyone know where the relay for this would be?
I found the relay. It was in the fuse compartment under the hood, driver side. It's the small black box relay that's nearest to the front of the car. I removed it and the pump stopped. I looked around in my w210 if there was the same fuse i could use off that car, but didnt find one. However, i put the relay back and now the pump doesnt go on. My guess is that the relay is now completely toast. I'll buy one tomorrow and replace.
Hope this helps anyone coming across the same problem.
'12 Mustang 5.0, '89 Supra Turbo, C55,
