E-Class (W211) 2003-2009
Dynamic Seats? Help..
Old Nov 18, 2011 | 11:15 AM
dsm2925's Avatar
W211
Unhappy Dynamic Seats? Help..
i have the dynamic seats.
i was told they massage .. but i can make it do it.
it touched the pulse buttom and nothing..
Old Nov 18, 2011 | 11:22 AM
Granada's Avatar
E-Class S211
Hi dsm2925,
does the rest of the seat's functions work? When activating the pulse massage it takes a few seconds until it starts. In the beginning my mother in law also had the feeling that pressing "pulse" wouldn't work. She was just sitting a bit too relaxed - the massage only works for your lower back.
Regards
Ruediger
Old Nov 18, 2011 | 11:25 AM
dsm2925's Avatar
W211
i will try again. maybe i was actually expecting a true massage
Old Nov 18, 2011 | 12:45 PM
Barry45RPM's Avatar
2015 ML 350
You have to move the lumbar support more forward into your body's small of your back. (Like a fist in the small of your back.) The masage feature makes this fist go up and down about slowly with 3 inches travel via a motorized cam or some such nonsense. Its NOT a vibrating type of massage.
Your "fist" is not extended enough and is moving up & down inside the seat and since its not extended out far enough, you can't feel it on your back.
Old Nov 18, 2011 | 01:00 PM
dsm2925's Avatar
W211
so its more like a fist going up and down?
Old Nov 18, 2011 | 01:30 PM
AzCamel's Avatar
10 GLK350/ 15 Accord/ 94 Supra Turbo
dont expect to much from it, the center lumbar support, imagine you adjusting it all the way in then out, that is all the pulse do, not much of a massage.
Old Nov 18, 2011 | 02:37 PM
gaazmon's Avatar
2009 SL550 Roadster Diamond White, 2008 CLK550 Coupe Obsidian Black
ya its not that useful the pulse function. the one in the S/CL/SL is better cause it does your upper back as well since the function for "under the thigh section" on the E version is replaced with "upper back adjustment" on the S/CL/SL since the thigh area on those seats can be adjusted back on forth making the bottom of the seat longer or shorter.
Old Nov 18, 2011 | 05:31 PM
Barry45RPM's Avatar
2015 ML 350
Exactly... a fist rolling up & down the small of your back only.
Old Nov 21, 2011 | 09:13 AM
dsm2925's Avatar
W211
so i found a buttom in front of the seat that says dynamic.. i thought the dynamic was always on.. duh me!
i realized the pulse on my back.. works good when you have the seat warmer on..
Old Nov 21, 2011 | 09:23 AM
Granada's Avatar
E-Class S211
No, the dynamic mode is being stored to the settings of your seat's positioning. Set dynamic on, save the settings again and dynamic will be enabled each time you start the engine. And remember: the dynamic- and the pulse-button are lit by an LED when active. But anyways its good to hear your system works fine! Regards Ruediger
Old Feb 7, 2012 | 10:34 AM
dsm2925's Avatar
W211
i just noticed that theirs 2 settings for the dynamic seats on the cluster options
Old Feb 7, 2012 | 10:47 AM
Benz-O-Rama's Avatar
Sounds like you need to spend some time with your owner's manual
Old Feb 7, 2012 | 11:53 AM
dsm2925's Avatar
W211
^ haha!
