E-Class (W211) 2003-2009
Please Help
Old Dec 5, 2011 | 06:43 PM
chisler's Avatar
E350
Please Help
I took my car to the stealership because the check engine light was on and they told me I had to replace the engine wire harness it was covered by the warranty but they told me the check engine light will still be on because the HID's caused the PREM sensor to fail.
Have never heard that the HID's would cause this sensor I never heard of to fail. Has anyone heard this to be true? They said with labor it would cost $492 but it would eventually happen again.
Old Dec 5, 2011 | 07:25 PM
redcoupe's Avatar
11 ML350
I guess im a idiot but what do u mean by 'PREM' sensor?
Old Dec 5, 2011 | 07:27 PM
chisler's Avatar
E350
is is the Oxygen sensor? not sure just going by what they told me over the phone?
Old Dec 5, 2011 | 07:34 PM
redcoupe's Avatar
11 ML350
I would def get a better description of what they're gonna replace. The HID's don't really affect the engine wiring harness
Old Dec 7, 2011 | 01:40 AM
chisler's Avatar
E350
so i got my car back from the stealership they replaced the engine wire harness and the left cam solonoid.
they said the HID's caused the coolant sensor to fail so the warranty does not cover that. has anyone heard of the HID's causing the coolant sensor to fail?
got the test report the code is 1337 and the event is 1897.
on the test report is says for event 1897 this fault
can be ignored and erased however the tech told me when
they erased it the code 1337 would appear again.
Old Dec 7, 2011 | 12:17 PM
Mike_W's Avatar
2013 CLS550, 2013 GLK350 4-Matic
Are they aftermarket HIDs?
Mike
Old Dec 7, 2011 | 12:30 PM
chisler's Avatar
E350
Mike
yes
Old Dec 8, 2011 | 12:00 PM
Mike_W's Avatar
You asked for help and I'm not sure how helpful this answer is, as it seems obvious, but depending on how much this bothered/cost you, you might want to get a second opinion at a good Indy shop.
Mike
Old Jan 6, 2017 | 10:37 AM
Benztech777's Avatar
2007 Mercedes Benz CL 550
I am working on this same problem with my own car also a friends car too. Seems these codes appear in a group and there is an answer for these faults to all be happening at the same time. My problem happened one day when I started the car and there was a surge in the engine and the check eng light came on. My 07 CL 550 was in need of a new main battery as it was old and the idle was around 650 causing a lot of stress on the alternator. But I have seen this issue on 2 cars all with the same group of codes.
Sticky Throttle actuator, O2 sensor codes, Code 1337 alternator serial interface, O2 sensor heater. I am of the thought that these codes are ghost codes a result of one problem and these codes always appear in this group. I am currently digging through forums etc for the answer to this group of codes and what ultimately fixes it in the end. Anyone with this group of codes that all appeared at the same time please post your experience and what actually fixed the problem in the end. Your help is much appreciated thank you!
Old Oct 5, 2017 | 01:33 AM
MarkE39's Avatar
W204 C280
Hi. Having this exact problem on my 2008 W204 C280. Any update on this problem. Don't know where to start.
Old Oct 5, 2017 | 08:50 AM
MarkE39's Avatar
W204 C280
w204 280
hi. Just want to ask if you were able to fix the problem of your car? Thank you.
Old Oct 5, 2017 | 02:07 PM
Strigoi's Avatar
2001 E320 Wagon, 2006 LBZ Silverado, 2007 E63 (sold), 2001 E55 (sold)
Benztech777 hasn't been on here in months and won't see your post. Try PMing them instead of repeatedly asking in the same thread.
Old May 23, 2018 | 05:45 AM
Vijay Relia's Avatar
A180
Hi
I am having the exact same problem, did you finally solve it. I know lots of time has elapsed.
Old May 23, 2018 | 10:08 AM
Strigoi's Avatar
Originally Posted by Vijay Relia
Hi
Did you even bother to read my post above yours?
Old May 29, 2018 | 07:57 PM
Redwood415's Avatar
92 W124 500E, 93 W201 190E, 11 C207 E350, 05 W211 E55
First priority for an advanced tech is to load test battery, low voltage will cause all sorts of odd codes that will have rookie techs scratching their heads and chasing things that aren't there. Why not find a good reputable indy shop to get a second opinion? It cant hurt..
Old May 30, 2018 | 02:20 AM
A180
Thanks for your reply. New Battery is installed and Indy says, it's the ECM.
Alternator and regulator was tested and was ok, Throttle body was changed, O2 sensors were changed. LIN bus was checked.
But I am not convinced it's the ECM.
Stuck !!!
Old May 30, 2018 | 12:47 PM
Redwood415's Avatar
I'm with you, Very rarely is it the ECM and usually when a shop can't find the issue they will pint to the ECM as a last resort. I have had this happen twice on W202 and W210 and both times the problem was still there!! it wasn't the ECM...
Old Oct 6, 2019 | 06:21 PM
MiltonM's Avatar
2006 c230 Sedan W203
Same issues as yours
Stuck !!!
I got the same Issue, got errors 1337 Alternator serial interface, throttle body jamming, right O2 sensor, etc..... Did you get to fix yours?
Old Oct 7, 2019 | 01:09 AM
A180
Nope, nothing yet. Sorry mate
Old Oct 7, 2019 | 03:09 PM
MiltonM's Avatar
Thanks!!
Old Oct 9, 2019 | 11:36 AM
e350forme's Avatar
fleet
You might want to start your own thread for more detailed help
Old Oct 10, 2019 | 01:42 AM
Strigoi's Avatar
You expect this idiot to be smart enough to do that when they can't even post in the correct section for the vehicle they own?
