Brake wear sensors for my 2005 E500 Sedan.
2018 GLC 300
After looking on EPCnet it looks as though I have three wear senors on my car, but my question is. Are they all the same senors just with different part numbers? I ordered some rotors and pads off the net, but I'm going to Oreily to get some new senors. I may not even need them, but I want them to be on hand just in case I need them since Eurosports garage is allowing me to supply my own parts. My E-500 is at 100k, and we actually went to trade it in for a 2010/11 this last weekend, but couldn't find a used preowned certified with a P2 package. My wife decided to keep driving ours until we find one. Our brake wear light is on so I need to get the brakes fixed as cheaply as possible.
It shows I need 2115400717 and 2115401717 senors. Are these really the same senors? If not ..What's the difference.
S6 LP640 E500
The rear and front passenger sensor has a oval plug while the driver has a oval with more square corners plug, but diffently different in shape.
Received 4,429 Likes
'71 Pinto
Difference:
2018 GLC 300
Does anyone know the size of the hex bolt to remove the rotor off a 2005 e500? Meaning the size of socket I need to remove it.
Thanks.
Thanks.
Funny, EPC provides 2 different part #s, but if you look on parts.com, they indicate that the front driver plug (2115400717) has been superceded by the same part #s for the passenger sides (2115401717).
'71 Pinto
MY03-05 equipped with 2 front sensors left 0717 (50% wear) / right 1717 (100%), rear right 1717 (100%) MB eliminated left sensor from series production MY06 reason for parts.com noting 1717 replaces 0717 as it concerns front.
10 speed bicycle
The 50% sensor was eliminated due to interference with AM radio stations on all 211's. Any 211 no matter the year, would have the 50% sensor removed at brake service. There is a DTB regarding this. US market 211's will only have brake wear sensors on the right side.
'71 Pinto
P-B-82.62/499 - upon customer complaint of AM interference
If DIY, your choice to replace 0717 (available @ autohausaz.com) if you decide not to replace go ahead and cut wiring but connector must remain plugged into harness. Furthermore, due to removal computer may instruct “check brake linings” at future maintenance even if linings are new - so it reads.
2018 GLC 300
10 speed bicycle
So it probably better to leave it on if it can leave a meassage? I've complained to the dealership for years about how crappy AM is on my radio. They never once mentioned anything about this. They always blamed it on my tint. I wonder if it could affect FM in anyway? Lately my FM has been a bit scratchy.
2018 GLC 300
2005 E500 Base
I've decided to change my own pads and disc myself. Front and rear. I've pretty much figured out the SBC issue and the wear sensors, but i'm a bit concerned about the rear dics with the emergency brake. Am I going to run into any problems here? When I top the brake fluid off what type of fluid should I use? Dot 4 or Super Dot 4. Any onther suggestions or hints will be greatly appreciated. I've done of few brake jobs, but never on this car.
'71 Pinto
Here are the e500 EPC part lists, confirm replacement with your dealer.
06 E320 CDI (GONE), 14 Jeep GC EcoDiesel, 01 Disco II (GONE), 09 BMW X3 3.0 Si Xdrive
If you cut the wiring after this you must connect both wires to close the circuit and you will be ok (no warning messages).
