2003 E320 Water behind driver seat..car not starting..HELPPPPP!!!!
Hello
I live in Vancouver BC Canada and it has been raining hard recently and I noticed that the carpet behind the driver seat is soaked.
I've been researching about clogged drains, but have had no luck for how to solve this problem.
As I tried to start the car today, it did not work. I'm thinking these problems are related...someone help me please.
Received 4,446 Likes
'71 Pinto
Check water collector @ wipers – clear debris and inspect drain line (#7, post 4) http://www.benzworld.org/forums/w211...-draining.html; check sunroof water drain channel for debris located at rear; driver & passenger side drain lines (post 10 & 11); front SAM & interior fuse https://mbworld.org/forums/3652658-post8.html panel for moisture caused by clogged drain(s).
