E-Class (W211) 2003-2009
To those that removed there CD CHANGER
Old Jan 14, 2012 | 10:00 AM
Ez-2-spd's Avatar
NEW HERE, SAME SCREEN NAME ON OVER 15 FORUMS
I have seen alot of threads on installing and removing the cd changer but none explain what to do with the fiber optic cable from the cd changer, when you disconnect them from the cd chager the radio goes black and displays the MB LOGO... I have no use for the cd changer and want to use that compartment for something else...
** THIS IS NOT THE COMMAND RADIO **
any help or advice is greatly appreciated in advance!!!!
-Brian
*NEW MB OWNER*
Old Jan 14, 2012 | 02:40 PM
Craftysince86's Avatar
W211
I remember when installed my comand (I know you don't have a comand) but when I installed mine and I did not connect the cd changer my head unit wouldn't work, not sure if it works the same with like just a regular a50 unit or whatever you have.
Have you tried just leaving the fiber disconnected?
Old Jan 14, 2012 | 09:59 PM
Ez-2-spd's Avatar
Yepp I tried leaving it disconnected but it wouldn't work :-/ I'm thinking about gutting the entire unit and now going double din touch screen with the Bluetooth it has all features audio50 has and more.. Tried everything this evening to allow it to work with our changer but once removed entire radio goes out... Hmmmm
Old Jan 14, 2012 | 10:49 PM
Cartronics's Avatar
Former Vendor of MBWorld
05 CL65 AMG, 07 Ferrari F430, 03 Range Rover HSE
All you need is a fiber bypass. Just put it on the CDC fiber cable.
Old Jan 15, 2012 | 08:49 AM
Ez-2-spd's Avatar
pm sent for more info...thanks!
