Car DVR Solution (Preferably Concealed)
Not sure if it comes in Class 10 though...
Also, it comes with a 12V Cigarette lighter adapter. I'm going to see if I can route this effectively to my rear cigarette lighter so I can still make use of my front one (i like to use it to charge my phone). If that doesn't work, I'm going to see if I can get one of those custom wiring harnesses that work with the dome fixture.
http://dod-tec.us/products/dod-gse55...-with-gps.html
This apparently DOES give you the ability to manually shut off the built in sound recording, and has the benefit of a little screen. Not sure about being able to not record speed however. The built-in screen is a huge plus IMO, because otherwise to fully configure the device you have to connect it up to a display via mini HDMI to see the on-screen menus.
Also, I would highly consider Mackhack's 12v cable from the OCP. I had to run the power cable across the headliner, down the A pillar, under the carpet, and to the center console. Adding a cable down the A pillar is also dangerous as it may interfere with proper deployment of the curtain airbags. I had made the front cigarette lighter "always on", so I could not use that, and I was forced to remove the entire cupholder/storage compartment, and tap in to the rear power point which remains switched. Separating interior panels and forcing even a thin cable in to gaps is VERY difficult in a Mercedes possibly because of the very close manufacturing tolerances (as compared to a SAAB and Volvo I had previously). The good news is that the device I have takes 12 volts directly in, with no DC-DC voltage adapter. I just cut the end off the supplied cigarette lighter plug, and spliced it in, along with an in-line fuse.
Enjoy!
Bought a GSE550. I like everything about it except that it simply won't power on about once a day. Usually my first trip is fine, but then the car sits for a while, and the second trip it won't work. I have to do a hard reset with a paperclip and then it works fine again until the next day. I'm going to try and return it and buy another one, or find a competitor's product.
While it does everything it says, the build quality is obviously suspect and it appears to be extremely expensive junk from China. It costs about 4x as much as other ones, but I need a "set it and forget it" solution that doesn't require a hard reset every day.
If you look closely, there's two almost identical companies selling the exact same product in the states:
dod-tec.com
dod-tec.us
Very sneaky. One of the sites even has a tutorial to find out if yours is a knockoff version or not.. I have no idea what I got, it came from "DOD Technologies USA LLC " on Amazon.
Like I said, the functionality seemed fine, but the daily crashes and build quality are not what was expected for the price of a PS3.
http://www.v-security.de/safedatafra...cam/index.html
English Link : http://www.acme-online.de/en/
I rather have a little bit of lower quality (and we still speak of HD quality) but I know it is working and doesn't require a reset every several hours. But that is all subjective of course.
http://www.supercircuits.com/Digital...s/Mobile-DVRs/
