Car DVR Solution (Preferably Concealed)
Basically I'm looking for something like what you see on the video below but something I can have professionally installed so it is completely concealed. Any ideas for any products? It is a real shame the "Go Pro" cameras don't support continuous recording where it deletes the old video to make room for new when the card fills up...
http://www.youtube.com/watch?v=8o2P_mxRWiY
I can imagine it coming quite handy in certain situations where you'd need to prove something happened the way you say it did. I can remember this one incident where someone was driving in a parking lot and some kid was driving doughnuts and stunt-driving all across the parking lot and slammed into this poor guys car who was driving on his own lane minding his own business. Luckily I saw what happened and dialed 911 and when the kid tried to get away after inspecting the damage I told him I had his tag number and the police is on the way. When the police showed up he tried telling them he was just minding his own business when the other car crashed into him. Yeah right. Good thing I was there, as the the other guy's car was totaled...
http://www.amazon.com/DOD-GS600-Logg...111111&sr=8-11
- Records forward vision, along with GPS coordinates, speed, and G forces.
- Can be set to continuously loop record
- High resolution, but the optics are not quite up to it - but still very good.
- Best feature is that it has a little battery onboard so that it gracefully shuts down and starts up again. I have it permanently wired to switched power.
- Worst feature is there's no way to permanently shut off the built-in microphone. As a result it's always recording conversation, me singing, etc. I guess I could disable it by poking it out, or something.
- The included software is just "OK" - it works and will allow you to review video and see your car's travel on google maps.
- The 32gb microSD card I have in it, loops about ~8.5 hours of video.
- It's not "concealed" but behind the rear view mirror, it's not /too/ obvious.
- This model also does the "file to file" recording, but is configurable to do it every 5, 10, 15 minutes. In the 10 minute setting I have it on, I have not noticed any missing seconds in between clips. Other users have stated that buy using a fast microSD card, the "gap" is eliminated.
Here a sample I recorded in real-time:
http://www.youtube.com/watch?v=c-MktGSLW6o
(make sure you watch it in high resolution)
Is there any way just to disable the speed stamp and keep the other settings on? Ideally I'd like to just keep the time and date or time and date + GPS coordinates only. From where did you get power for this? I'd like to have this professionally installed behind the rear view mirror so it is not really visible. It would be awesome if you could post some photos of your installation along with some guidance on how you hid the wires and from where you got power.
Thanks again! This could really come in handy one day not just for myself but if i witness something and need to provide a record of it later.
Thanks again!
http://dod-tec.us/products/dod-gse55...-with-gps.html
This apparently DOES give you the ability to manually shut off the built in sound recording, and has the benefit of a little screen. Not sure about being able to not record speed however. The built-in screen is a huge plus IMO, because otherwise to fully configure the device you have to connect it up to a display via mini HDMI to see the on-screen menus.
Also, I would highly consider Mackhack's 12v cable from the OCP. I had to run the power cable across the headliner, down the A pillar, under the carpet, and to the center console. Adding a cable down the A pillar is also dangerous as it may interfere with proper deployment of the curtain airbags. I had made the front cigarette lighter "always on", so I could not use that, and I was forced to remove the entire cupholder/storage compartment, and tap in to the rear power point which remains switched. Separating interior panels and forcing even a thin cable in to gaps is VERY difficult in a Mercedes possibly because of the very close manufacturing tolerances (as compared to a SAAB and Volvo I had previously). The good news is that the device I have takes 12 volts directly in, with no DC-DC voltage adapter. I just cut the end off the supplied cigarette lighter plug, and spliced it in, along with an in-line fuse.
Enjoy!
Thanks again!
@ apl175, thanks for both the links. I assume you'd buy the newer version as it doesn't look much bigger than yours ? The video is terrific.
The only question I have is re the 30fps frame rate. No tv that I know of, in the U.S., supports it, so how did you do that youtube vid ?
Sorry I can't agree...
Seriously, who here does not go 5-10 or so over the limit? Last thing you want if you are the witness to a crash is to submit a piece of evidence that incriminates yourself even by 5 or 10 mph. If someone wants to go to the trouble of calculating your speed from the video let them do it. I don't want the speed permanently etched on the video. Also from the research I've done, sometimes the speed calculation of the unit is way off and that's another reason why you don't want possibly erroneous information on there. I'd just want the time and date and that is it.
FWIW apparently the company heard and understood this concern loud and clear. From the research I've done, I found out that the later units of the model recommended was shipped with a firmware update to turn off the speed and GPS coordinates and I believe the new unit that supersedes the one recommended also has this capability.
With the ability to turn off the information I have no need for I am happy that I found a solution to record a video of what happens in front of my car, nothing more, nothing less...
apl175: Thank you so much for the great recommendation!
You can't have both as someone said it already. The speed can be calculated regardless. But guess what. Your airbag control unit has a memory inside which records about 5 to 20 seconds and overrides the data constantly as they become available. I don't know the exact time frame but a buddy of mine got in an accident and the court wanted the data to be extracted and presented. That's why I know. So everyone stay safe and watch your speed. It might be recorded someone and used against you if you don't expect it the least.
I'm pro camera for the last year or so and will put on in my car myself. We have 2 intersections where you see at least one car every single day of the week running a red light. Having this on tape might help one day someone innocent. And running redlights became a normal thing on our roads in the last few years. It's almost like it's optional to stop at red if you want but you don't have to. Many get killed by these recless drivers
By the way I don't think anyone is going to install this in their car (myself included) because they speed excessively or drive recklessly. If anything it is to simply document what happens in front of their car.
Respectfully.
I made thus very clear but if you want to interpret my text differently then oh well so ve it!
What does the camera mount to? does anyone have pictures of their setup?
http://dod-tec.us/dod-gse550-car-dvr...-with-gps.html
More details...
http://dod-tec.us/support/
I've had mine since early September, and I hardly notice/remember it's there unless I see something interesting that I want to review....
More details...
