DIY How-To - Adding an Ipod to the Center Console for under $12
E350 Sedan Sport
Sorry I couldn't imbed the pictures (too many).
See the attacments for my install, I'm really happy with how it turned out
C320 CDI Estate, E500 4M Wagon
Well done! There are pros and cons of every install eh? I've found that the E is very easy to work on, add add things to, in most areas. The center console/stack comes apart easily and is a fairly painless area to route cables. Two that aren't so easy are the roof console and wagon tailgate!
By far, the easiest way to wire ipod dash-display (and ONLY way to have COMAND display) functionality in the E is with the iTronic from Cartronics.
The M/B iPod connector must be routed back to the AGW (in the trunk!), to rear of COMAND, and to the CAN BUS in the passenger footwell. A seasoned installer will claim that routing cables to the rear is a simple job, but if you're not familiar, it will take some research and several hours of labor.
The M/B unit can navigate to podcasts, and play unlimited songs....but is somewhat of a PITA to back out of menu's, etc. ITronic has other limitations but is great for display functionality. (also has other non-iPod uses).
In the end, I agree that the stock location for the audio is unsat! Also, either display option is about $700 more than you spent! You can also easily add jumpers to the cig lighter power and free up your front side of the cig lighter. In addition, you will likely need a ground loop isolator inline with the audio connection to eliminate the hum from the USB charger.
Also beware that your cord routing blocks the emergency trans unlock (for dead battery towing)
Congrats again, and happy listening.
Smash
Smash
E350 Sedan Sport
I've found the car easy to work on too. So far, my installs include: Navigation, Bluetooth/Phone, and Voice Control. The available iPod options just seemed to much effort and cost for two little gain, so I just went with the generic harness route.
No hum from the USB to this point! (hope I didn't jinx myself by saying that)
On the "trans unlock" so THAT'S what that hole is for, I'll have to re-look at that. If it does block access, maybe I'll drill another hole close by and cut a slice between the holes so I can slide my cables through to the new hole?.
I've had luck with the Dension Gateway 500, which I wired up last year and allows me to control any usb media or ipod with comand or the steering wheel buttons. I can't remember why I didn't go with the itronic at the time...
Smash
