E-Class (W211) 2003-2009
Side mirror lights
Old Jun 30, 2003 | 02:26 AM
kengi's Avatar
e500
Question Side mirror lights
Hello Guys I have a question...the side mirror lights has a light under it for vision at night. I don't know how to activate them. I tried settings, door opening, alarm setting, etc. Does anybodies lights working?
thx
kengi
Old Jun 30, 2003 | 03:18 AM
bmms8's Avatar
MB
Re: Side mirror lights
thx
kengi
hmm, they should turn on everytime you lock/unlock or open a door..maybe they are broken, i would go to your dealer, or look iin the manual for possible problems
Old Jun 30, 2003 | 03:19 AM
muhri's Avatar
'18 AMG GTR '16 BMW M3 - '05 Porsche Carrera S
thx
kengi
Mine work when I unlock the car and its dark - the car has a sensor to determine if its dark enough to light them up. Maybe you have been trying in the sunshine. Just worked last night when I unlocked my car in the garage.
Old Jun 30, 2003 | 03:24 AM
kengi's Avatar
e500
I tried when it was dark and still no go....dealership time
Old Jun 30, 2003 | 07:21 AM
craigng's Avatar
Before you do that!
Check your settings in your instrument panel - there is a submenu under settings called lighting. You should make sure that the setting for 'surround lighting' and 'exterior lighting' is switched on!
If not, your surround lighting will not activate even if it is dark outside.
Old Jun 30, 2003 | 07:45 AM
KShortill's Avatar
2004 E 4matic StationWagon
Another Guess
Just guessing here, but I initially thought the delayed headlamp shutoff was broken in my car, but then it turns out that the delay feature only works in the headlamp switch is turned to "auto" (even though enabled on the computer/instrument panel). Might try that and see if that works.
Old Jun 30, 2003 | 09:27 AM
jim256's Avatar
'03 Mercedes E320
kengi: Also, be sure the interior door switch light is activated so the front overhead lights come on when you open the door. (middle switch of three forward switches on overhead panel) If that switch is not set, the mirror lights don't operate when you unlock the car
Old Jul 2, 2003 | 10:25 PM
kengi's Avatar
e500
thanks alot guys I'll try it
Old Jul 4, 2003 | 01:01 AM
kengi's Avatar
e500
IT WORKED!!!THX GUYS THE TRICK WAS IN THE INTERIOR TURN ON LIGHTS ON THE OVERHEAD CONSOLE!
Old Jul 4, 2003 | 01:14 AM
bmms8's Avatar
MB
hey, nj, but do they turn on at night time when you open the driver door? or do you have to do it manually?
