Annoying Vibration (and dealer) Help!
I am meeting with the dealer tomorrow to discuss the issue again and would appreciate any information what this vibration might be. I have asked them to check the flex discs, support bearing and driveshaft balance, but so far, they refuse. The car is still under warranty by the way.
Any suggestions will be greatly appreciated...........
-Dave
I can't believe the arrogant attitude I am getting from the dealer...and my wife is telling me "I told you to buy a BMW" (like that helps)..
Thanks for all of your help and input. I will update everyone as the saga continues and I work my way up the MB corporate ladder...
1. The driveshaft was found unbalanced. At high speeds it vibrated the whole car.
2. One of the shocks (rear driverside in my case) had a bad weld.
3. Tie rod end had gone bad and needed replacement.
4. Ball joint (front passenger side in my case) gave and needed replacement.
Mind you, these aren't things that happened on my mercedes but still applicable. Unfortunately, many MANY other things can cause the symptom you have described. Hopefully checking these things (many can be done yourself) may help you solve the issue. Good luck.
-Dave
