E-Class (W211) 2003-2009
The dreaded M272 Balance Shaft
Old 08-28-2018, 08:52 PM
  #551
cetialpha5's Avatar
Received 1,498 Likes on 1,170 Posts
Originally Posted by Shack1
I bet mine was at a lower mileage than yours. 44700
I bought the car in 09 with 22k, so if there were reports of this issue they were FEW.
I did plenty of research and tried to get estimates from indys but was turned down. At least I got 15% off as I was well over a year from the tiered settlement date.
I get a little pissed I admit it, when someone says I don't know what caused an obvious wear problem due to bad materials.
Still pissed that MB didnt cover the whole repair and made a car thats already had this and a transmission issue, im only at 48000 and had the transmission go to limp mode,
which I had repaired by shipping the control module and had its electrics repaired. Then I the damn indy shop didnt put the trans gasket in correctly and it leaked.
So I bought a transfer pump and another new gasket and did it myself. NO leaks and working great now. Next issue the Fing SBC brake bs!
Keep reading the forum. There's a surprising development where MB just decided to cover SBC up to 25 years unlimited miles. Before it was just 10 years so now you're back in coverage.
Old 08-28-2018, 09:30 PM
  #552
95viper's Avatar
2007 cls550
Hey Shack1, Now that is great news for you on the SBC!
i have a 08 C350, 07 CLS550 and 11 E350 so as much as I want to complain about the sprocket the cars are awesome.
Old 08-28-2018, 10:37 PM
  #553
Shack1's Avatar
06 E350
Great news. Do you have a link to the bulletin? or a site?
Old 08-28-2018, 11:21 PM
  #554
95viper's Avatar
2007 cls550
Either click on that search button top right corner and type SBC or scroll down about 15 posts in this forum and it will be obvious.
Old 08-29-2018, 01:02 AM
  #555
Shack1's Avatar
06 E350
Thanks Capt. Obvious
Old 08-29-2018, 08:49 PM
  #556
95viper's Avatar
2007 cls550
Cool. Maybe we can talk about how to fill the gas tank next
Old 08-29-2018, 09:13 PM
  #557
Shack1's Avatar
06 E350
HIgh test diesel right, Capt?
Old 08-30-2018, 12:33 PM
  #558
Travis Ceccacci's Avatar
2006 Mercedes C230 Sport
I hope someone finds this helpful.
Even if your M272 engine serial number falls within the range of those with bad balance shafts DOES NOT automatically mean it is bad!!
Here is an easy way to check. Rotate the engine to TDC (tope dead center) which is when the 305 mark on the crank pulley lines up with the arrow or mark on the engine block above the crank pulley. You will need a 19mm socket and long breaker bar. These marks are hard to see if you have an older vehicle with 150K miles like mine so I had to mark it with craft paint for future reference haha.
Once you do the that remove camshaft position sensors (I think it is two or three 10mm bolts). Look inside to see if the markings are all within the circle. If they are, CONGRATS!!!! You don't have a bad balance shaft. See youtube video below!!
Old 08-30-2018, 01:17 PM
  #559
95viper's Avatar
2007 cls550
This is helpful but it doesn’t mean that you don’t have a bad balance shaft. This means that you haven’t jumped timing yet.
The scope of the gear is the only way to check. Or pull the timing cover of course but then you would be fixing the problem.
Old 08-30-2018, 01:57 PM
  #560
Shack1's Avatar
06 E350
Originally Posted by Travis Ceccacci
I hope someone finds this helpful. https://www.youtube.com/watch?v=XXQArmxXsnM
If you get codes P0017, P0016 at the same time 99% its the balance shaft.
I have read nearly all the posts, bulletins and websites on the balance shaft and have yet to read of a motor jumping teeth,
its not the balance shaft sprocket that keeps the timing.
Old 08-30-2018, 02:23 PM
  #561
Again, I think if the circles are in the center when you take off cam position sensors then the issue is likely the sensors themselves and not the balance shaft.
What do you mean it just means you haven't jumped timing yet? If the balance shaft was bad or damaged, I believe the timing gears on the balance shaft would be worn and timing would've already jumped. I could be wrong but I checked mine with this method, then changed the appropriate camshaft position sensors on the bank that throwing the code (I think it was one on each side but don't remember if it was the sensor exhaust or intake). That cleared the codes and I haven't seen them in 18 months (Knock on wood).
Old 08-30-2018, 03:13 PM
  #562
95viper's Avatar
2007 cls550
You guys are both right and the cam position sensors needing replacement throws in another variable.
Assuming those are good you can chug along and do nothing until the codes throw. Then in an emergency you need to schedule a repair.
I decided not to wait and did mine at my convenience.
The balance shaft does affect timing though. What happens is the gear wears down and the tensioner exceeds its limit. The cam gears get out of sync and there go the codes. Make sense?
so the video posted is correct that you don’t have the problem now by checking the windows but it doesn’t mean that you won’t get it.
Old 08-30-2018, 03:16 PM
  #563
95viper's Avatar
2007 cls550
Btw the cam sensors leak and the o rings get old and are known problems. They are relatively easy to replace so no sense in waiting on that. Save money by not needing to do that in an emergency and order at the best price.
Old 08-30-2018, 03:28 PM
  #564
Shack1's Avatar
06 E350
You said it could jump a tooth! We all know what occurs if that happens.
Old 08-30-2018, 03:44 PM
  #565
95viper's Avatar
2007 cls550
Hey Shack is back and reading up on this now. Of course it could jump a tooth. Just think about it. The chain would eventually have too much slack.
This doesn’t typically happen though because the codes throw that the cam(s) position is out of range first and people get it fixed.
With a balance shaft engine the teeth on the balance shaft gear worn down would cause it to jump timing and now you have more problems.
Old 08-30-2018, 03:46 PM
  #566
Shack1's Avatar
06 E350
Reading up on it now. LMAO
Even with the teeth gone, there isnt enough slack. Ill post a pic of mine so you know what we are talking about.
Show me a incident where this has happened?
pete diegan (02-01-2022)
Old 08-30-2018, 04:46 PM
  #567
95viper's Avatar
2007 cls550
Why is this so difficult to comprehend? If this is your gear and the only thing keeping that offset weight to stay in timing with the engine is the teeth then why would it not jump timing?
Old 08-30-2018, 04:47 PM
  #568
95viper's Avatar
2007 cls550
Old 08-30-2018, 04:49 PM
  #569
Shack1's Avatar
06 E350
Whats your deal with HAVING to be right? I love that you showed me a pic of what I just showed you. That's not the timing gear, would it matter if it jumped a tooth on the balance shaft?
Old 08-30-2018, 06:27 PM
  #570
95viper's Avatar
2007 cls550
Shack1,
I’m not trying to be a dik. I just don’t want people inspecting the cam windows and walking away that they don’t have the balance shaft problem because it happens to be in alignment that day. The post above sort of implies that.
Regarding timing. There isn’t a specific timing gear here. You seem hung up on that and are trying to disregard the importance of the balance shaft itself and the fact that it is a critical part of timing on these engines.
The balance shaft has to set in relation to the cam gears and crank. The weight has to be rotated to a mark and the chain has a link to line up. Then the crank and cam gears are set. All of this makes up the timing.
If it jumped teeth like it would in the photo the offset weight would spin out of timing and vibrate the engine.
Cool?
Old 08-30-2018, 06:36 PM
  #571
Shack1's Avatar
06 E350
Shack1,
Cool?
You win, your the winner, congrats I'll let you have the last post, after this one. Again congrats YOU WON! and I lost big time on this fing pos car! YEA!
Old 08-30-2018, 07:26 PM
  #572
N_Jay's Avatar
2007 W211 E350 4Matic / 2008 X164 GL320 CDI
Because it is an idler shaft / balance shaft gear wearing out and not a timing shaft gear.
Probably why they thought it did not have to be as hardened since there is minimal load.
Old 08-30-2018, 07:28 PM
  #573
N_Jay's Avatar
Shack1,
Cool?
If it is off a few degrees (a point or so) it will vibrate more than desired at some particular speeds (Maybe noticeable, maybe not). It is not the same as having the valve timing being off a tooth.
Shack1 (08-30-2018)
  #574
N_Jay's Avatar
I want the last post!
Old 08-30-2018, 09:26 PM
  #575
exhaustgases's Avatar
LS400
If the balance shaft sprocket is the soft material and wears out enough to let the chain skip it, that does not mean the other sprockets will lose timing, only if they get jumped as well from a very loose chain or wear just like the balance sprocket. Now that video could show a worn chain condition.
Shack1 (08-30-2018)
Quick Reply: The dreaded M272 Balance Shaft
