E-Class (W211) 2003-2009
Options for hard-wiring switched power
Old Apr 17, 2012 | 08:11 PM
irondad's Avatar
W205, X253, C190, W213,
I'm hard-wiring my radar detector and want switched power, but I am changing my cigarette lighter, the usual source for switched power, to always on (via the engine bay fuse option) so I need another source for switched power.
The fuse box on the left of the dash are not switched so that's not an option.
Any input into any sources of switched power under the dash or in the console other than the cigarette lighter?
Old Apr 18, 2012 | 11:21 AM
Efivehundred's Avatar
06 E55(SOLD), 03 E500(SOLD)
How about the OCP?
http://www.****************/products-...ware-retrofit/
Old Apr 18, 2012 | 12:59 PM
Mike_W's Avatar
2013 CLS550, 2013 GLK350 4-Matic
Here's another option - Leave the line to the cigarette lighter switched, disconnect it from the lighter and use that for the radar detector. Connect the lighter (through an inline fuse) to an unswitched source in the fuse box on the left of the dash. The lighter uses quite a bit of current - so I would not recommend this approach if you are actually using the lighter, only if you are using the lighter socket to power other electronics.
Mike
Old Apr 18, 2012 | 04:11 PM
irondad's Avatar
Originally Posted by Efivehundred
Cool product... unfortunately I have the Escort with the smart cord or whatever it's called so the power is down in the ash tray where I have the remote thingy installed.
Old Apr 18, 2012 | 04:13 PM
irondad's Avatar
Mike
Interesting approach... I guess 12v is 12v?
My lighter has an adapter with two USB ports, just used to power electronics.
Old Apr 18, 2012 | 04:43 PM
Mike_W's Avatar
Assuming that you'll switch to USB 3.0 someday - that is still only around 1 amp per port. Should be no issue.
Mike
Old Apr 18, 2012 | 06:01 PM
irondad's Avatar
Mike
Yeah... I picked the one that was 1 amp per port since that was was the chargers for my phone put out. There was a one-port one that stated "2.1 amps" and, not knowing much about electronics, figured that might not be what my HTC Android phone would like.
Old Apr 19, 2012 | 04:05 PM
apl175's Avatar
Running directly UNDER the center cup holder assembly (you have to lift the entire piece out) is the wiring harness for the REAR cigarette lighter that remains switched, even if you have made the modification to the front one.
Old Apr 19, 2012 | 09:28 PM
irondad's Avatar
That's EXACTLY what I'm looking for! What do I have to remove to find it?
