E-Class (W211) 2003-2009
Transmission reset cured the dreaded rough 2-1 downshift?
Old Apr 18, 2012 | 05:56 PM
irondad's Avatar
W205, X253, C190, W213,
I did the transmission reset and since then I've not had the rough 2-1 downshift that I had before on occasion.
The rough 2-1 downshift didn't happened all the time... usually while creeping (as in driving slowly... not acting in a lecherous, stalking way ) in a parking lot... so I'm curious if I've cured it or if I just haven't encountered the speed/deceleration that triggers the rough downshift yet?
Anyone else with this experience?
We've owned executive-class MB's since 73, and I have to say none of them have been brilliant with 2-1 downshifts, so maybe this is a Benz weakness to start off with.
Old Apr 19, 2012 | 01:10 AM
Barry45RPM's Avatar
2015 ML 350
The quick & dirty solution is to run the car as a 6 speed. (always in "C" mode.) Newer Benzes default to "C" when you start them.
1st gear is so low, that the car waits until you are almost at a stop before it allows the trans to drop into 1st, and still the engine is revving higher than 1st is expecting.
Old Apr 20, 2012 | 05:24 PM
charliele729's Avatar
09' E350 AMG Sport, 09' C300, 03' Honda S2K
Sometimes when i am not at a complete stoip, the transmission is not set back to 1st gear yet, a good example is a cali roll, the transmission would be a lil jerky because of the transition of going into first and at the same time stepping on the gas
