SBC BRAKES HOW TO DEACTIVATE
As long as your keys are not around you and the doors are not opened, SBC is disabled. To even make sure, you can go to the SBC box and pull up the lever and remove it from the box, this will def deactivate the SBC
03 E500 and Corvette
I use the power flusher that pressurizes the master cylinder adding fresh fluid and bleed out the calipers. Every 2 yrs I flush this way until each caliper flushes clear fluid.
