E-Class (W211) 2003-2009
steering vibration
Old Jul 9, 2003 | 12:52 PM
bmw2mb's Avatar
530
steering vibration
is it possible for the tire design/quality in this category (mich pilot hx mxm4 245/45 r17 95h) alone produce steering vibration around 50 mph?
they have replaced the front tires once and rebalanced several times by different dealerships. still a vibration around 50mph.
With the cont tires, i had no vibration, but a right drift. i have someone that will mount bridgestone Potenza RE750 245/45 r17 95w to see if the car drive better. well see.
also, does anyone know the difference between 95h and 95w?
Old Jul 9, 2003 | 01:01 PM
bmms8's Avatar
MB
Re: steering vibration
i believe it is, our 02 camry has a rattle like that. when we are slowing down, i believe around 30 MPH it rattles a lot. tire shop said it was the tires, and alignment.
Old Jul 9, 2003 | 01:46 PM
jyg e500 maybe's Avatar
2000 528BMW 5sp
Angry probably not tires
usuallly . michelins especially hx mxm 4 are of great quality. its possible go a bad one, Does dealer have a hunter 9700 balancer, it will detect and cure any balance issue if the operator knows how to use it,
Old Jul 9, 2003 | 02:38 PM
bmw2mb's Avatar
530
i will find out...they should since they are a brand new dealership. we have 2 in the area now. if the wheels are perfectly balanced, what would be the next solution? this is a brand new car.
Old Jul 9, 2003 | 02:59 PM
2000 528BMW 5sp
Cool h & w
are highest sustained speed rating for tire H is 130 mph W is i think 145
Old Jul 10, 2003 | 09:00 AM
FJPM's Avatar
2003 E 500 - Full option
Your vibration may be caused by the flange which may have been damaged.
Concerning your right drift, the E 500 has a sligh tendency to "copy" the road camber which is usually inclined to the right.
If there is a serious alignment problem you should noticed an uneaven tire wear.
Old Jul 10, 2003 | 09:37 AM
bmw2mb's Avatar
530
the problem was found by a local Firestone shop.
out of desperation, i went to firestone to have them mount the front with bridgestone potenzas. he put my front right tire on their balancer and noticed right away that my rim had a hop in it. he checked all the tires and also found 1 tire had a hop but the rim looked just fine.
once he put my best 2 wheels/tires on the front, i took for a test drive and steering vibration gone!
now i have to get the foreman to agree that a little local shop guy found the problem and get them to admit i have a defect rim and tire for needs replacement. i was beginning to think i bought a hi dollar chrysler.
Old Jul 10, 2003 | 10:37 AM
FJPM's Avatar
A rim can be very easily damaged with these low tires: just in falling in a small gap into the tarmac or by climbing on a pedestrian.
