E-Class (W211) 2003-2009
Rate the Lowering Kits
Old Jun 3, 2012 | 10:06 PM
otto6457's Avatar
E350
I'm getting the itch to lower my W211 just a bit to improve the looks and add a bit of performance also. Nothing crazy. I may go to 19" wheels later on. (love the HRE's), but the AMG wheels I have now look good.
Anyway, after some research it appears that there are 3 options. (actually there are 2 ways to do it, but 3 companies making kits.
The first and most common method is changing out the springs. The 2 companies using this method are:
1) Eibach. Seems to be the most popular brand, but there are plenty of complaints about fit and adjusting camber after installing the springs.
2) H&R. Appears to be almost identical to the Eibach kit in contents and installation. The only complaints I have found were concerning ride harshness. Seems the H&R's are stiffer than the Eibach's.
Now, both of these kits claim a 1-2" drop. I've measured my car and that's a pretty deep drop and I'm concerned about clearance over speed bumps and driveways. Not to mention split fenders which I found several examples of online.
Both of these kits are the same price and pretty cheap (under $300.00) and like I said, appear to be the same as far as install and adjustment.
The 3rd option is the KW Coilover system where coilover units replace the factory spring/shock set-up. It offers much more adjust ability. Not just ride height, but ride firmness is adjustable also. The ride height is adjustable with a simple turn of a collar at all 4 wheels so that I can fine tune the ride height for clearance and performance. The firmness is adjustable with a turn of a knob, which would be a nice option. KW is a major motorsports shock and suspension company so they have a lot of experience in the performance and racing field. However, these benefits come with a steep cost. The KW Coilover Kit comes in at a whopping $2000.00.
The installation of any of the three will be comparable. The KW system may be a bit easier since there is no mention of having major camber change problems like those with the other 2. None however, would be a major problem.
Anyway, if anyone has experience with any of these (in particular the KW's) please post them up.
Old Jun 5, 2012 | 02:04 AM
SoCal_AMG350's Avatar
'05 E55, '82 Porsche 911SC, '83 DeLorean
Im in the same boat as you wondering the same thing. My main issue with the H&R's and other spring set-ups is that it looks like the front sits slightly higher than the back. I've heard that you can adjust this through using different sized shims, but have not gotten a straight answer.
Looking forward to following the post and seeing what people say.
