E-Class (W211) 2003-2009
TPMS
Old Aug 4, 2012 | 11:26 AM
DansE5004's Avatar
2006 e500 4 matic
TPMS
How do I know if I have TPMS? 2006 E500 4matic. Got new tire quote and they listed TPMS valve stems to replace.
Old Aug 4, 2012 | 03:15 PM
konigstiger's Avatar
'71 Pinto
Attachment covers MFD for feature confirmation, OEM TPMS valve is part # 0014014213. To comparison shop, you may want to check http://www.tirerack.com/about/contact.jsp
File Type: pdf
Old Aug 4, 2012 | 07:22 PM
vettdvr's Avatar
03 E500 and Corvette
The TPS on my 99 Corvette is origional. There is a Lipoly battery to power it with about a 7 yr life so I expect failures on the sensors after 11 yrs. It is amazing tire co's find another way to dig $$. UMM nitrogen is so much better, balance,, road hazard, valve stems,, did you want us to put the tires back on,, in the same place. Dig DIg. Why not just try something creative like, Bla Bla tire.. $@@@ installed drive out price, vs putting it up as $99 special and oh by the way $50 addon's bring it to..
Old Aug 5, 2012 | 12:51 PM
otto6457's Avatar
E350
^^This^^
Tire stores are notorious for this nonsense.
Did the store tell you why you supposedly need new tire pressure sensors? If you didn't have tire warning light before, you don't need new sensors now. Unless of course they broke one. I probably replace a couple of sensors a week due to tire stores breaking them.
Old Aug 5, 2012 | 03:47 PM
DansE5004's Avatar
2006 e500 4 matic
I have not had the tires installed yet. Waiting for them to arrive. On the invoice I notived the TPMS valve stem. However...as far as I know...I do not have TPMS at all. No dash light and no option to recalibrate on the menu. I never thought abought TPMS before now and assumed I do not have that option. Is TPMS standard and I just never knew it was there?
Old Aug 10, 2012 | 07:42 PM
ShopTPMS's Avatar
Former Vendor of MBWorld
2010 E350
2006 vehicles it was not required, but was available as an option. Two ways to confirm, if you have solid metal valve stems that is the first hint, rubber stems means no TPMS, or call the dealer with your VIN to find out. Tire shops are supposed to change the service kit (nut & rubber washer) when they change your tires. The rubber gets old and cracks and may cause leaks. However the service kit cost a lot more than just an old fashioned rubber valve stem.
Old Aug 10, 2012 | 09:16 PM
Mike_W's Avatar
2013 CLS550, 2013 GLK350 4-Matic
Well, it is kinda simpleminded - but if you are near an air compressor, drop the pressure in a tire down to 20 psi or so, and see if you get a warning.
Mike
