E-Class (W211) 2003-2009
Passenger headlights not working after facelift
Old Sep 14, 2012 | 10:01 AM
kaybal's Avatar
2003 E500 (W211)
Question Passenger headlights not working after facelift
I have a 2003 E500. I bought the new headlights (2007 - 09) to have a face lift. I changed the drivers side first, tap the wires to go to the new connector using a good step by step guide i found on this forum. I switched on the lights, high and low beam, signal and they worked fine.
I did the same with the passenger side and when it was done, no lights came on. It wasn't working. To be sure if my new headlights is not faulty, i replaced it with the old original headlight and that did not work too. This was working before i swapped it. Well, a bit relieved that my new headlight is not faulty.
So, the question is, did i blew the fuse? Where is the fuse located? Why is the driver side headlight working and passenger side is not? What can be the problem? I didn't rip any wire.
Old Sep 14, 2012 | 12:06 PM
konigstiger's Avatar
'71 Pinto
Check f66 (7.5A) @ front SAM - located engine compartment rear.
Old Sep 14, 2012 | 01:35 PM
kaybal's Avatar
2003 E500 (W211)
Is that the fuse box located just directly in front of driver under the hood? If facing the car with hood open, its going to at the far right.
Old Sep 14, 2012 | 04:40 PM
'71 Pinto
Yes
Old Sep 14, 2012 | 07:10 PM
kaybal's Avatar
2003 E500 (W211)
Yes
Looks fine. Fuse is not broken.
Old Sep 15, 2012 | 01:16 AM
'71 Pinto
Check the passenger side SAM control module located interior right front footwell (100 in diagram).
File Type: pdf
Old Sep 15, 2012 | 01:47 AM
benzmodz's Avatar
W203 slightly modified
Usually you change the SAM and the wiring with the facelift.
Old Sep 17, 2012 | 03:04 PM
kaybal's Avatar
2003 E500 (W211)
I can't find this SAP control module. I've checked the passenger side. Exactly where is it located?
Old Sep 24, 2012 | 11:07 AM
kaybal's Avatar
2003 E500 (W211)
I can't find this passenger SAM module. Can you please tell me exactly where it's located?
Old Sep 24, 2012 | 01:18 PM
'71 Pinto
See attachment
File Type: pdf
Old Sep 26, 2012 | 09:40 AM
kaybal's Avatar
2003 E500 (W211)
See attachment
I might look stupid asking this again. But I ripped the footmat out of the front passenger-side of my E500. There was no SAM module in there.
I'm sorry for asking this again. My car is a E500 2003, W211.
I took out the footmat, take off the carpet below that and I i found was some big hard yellow foam, and metals.
Old Aug 30, 2020 | 01:03 PM
Akshar Mahadeo's Avatar
W211 e240
Hi there, I'm having the same problem with my w211 e240... It seems as if there's no power going to my entire left hand side head lights and fogs.. How did you solve your issue?
Old Apr 4, 2021 | 12:46 PM
Hydro2113's Avatar
2004 E500 4Matic Sedan (Everest Green)
found SAM
See attachment
I have found myself down this path. I’ve located the interior passenger SAM unit. What am I to do at this point, is there a method to check this or is it simply a replacement.
~ to clarify, I’ve replaced the headlights on a 2004 e500 4matic. I have no voltage at the light, the frt SAM unit fuse f66 is intact and I’ve opened the passenger footwell compartment to reach the SAM unit.
Old Apr 4, 2021 | 01:13 PM
'71 Pinto
You are referring to right headlamp correct? Passenger SAM controls right headlamp via internal semiconductors. Since you will need MB diagnostics to transfer data if SAM needs replacement anyway, have someone pull fault codes using MB diagnostics.
Old Apr 4, 2021 | 01:34 PM
Hydro2113's Avatar
always appreciate your info. Thank you, I’ll have it checked out.
Old Jun 7, 2022 | 10:56 AM
'71 Pinto
Airmatic...
File Type: pdf
Old Jun 28, 2024 | 04:55 AM
Irshaad Sha's Avatar
W211 E240
Hi, having the same issue at the moment. Have you managed to solve the issue?
