E-Class (W211) 2003-2009
E550 creaking when steering
Old Sep 16, 2012 | 10:22 PM
Robaustin's Avatar
2016 E400, 2015 GLK 350
2007 E550. When I turn the steering wheel when stopped, I hear a creaking sound from the steering assembly or suspension. Thoughts?
Old Sep 17, 2012 | 08:15 AM
vettdvr's Avatar
03 E500 and Corvette
Ball joints?
Old Sep 17, 2012 | 08:53 PM
Robaustin's Avatar
Good thought. Could well be. I'll have them checked.
Old Sep 18, 2012 | 12:36 PM
konigstiger's Avatar
'71 Pinto
In addition, up to VIN B100720 there is a design modification to steering retaining plate (500 in diagram) allowing for greater clearance to resolve cracking/creaking noises heard when vehicle is stationary – part # 2116280511 MSRP about $28.50 if under warranty reference bulletin LI46.40-P-047549.
File Type: pdf
Old Sep 18, 2012 | 08:38 PM
Robaustin's Avatar
Thanks. I'll look into this!
Old Apr 12, 2013 | 11:11 AM
cb1234's Avatar
2007 E-350
Do you have the SB LI4640-P-047549? Can you post it if you do.
thanks
Old Apr 12, 2013 | 01:09 PM
VII's Avatar
VII
2020 S560, 2014 SLK55 (Prev. 2016 S65, 2013 SLK350, 2008 CLS63, 2006 E350, 2006 CLS500, 2005 C230K)
Didn't work for me
I replaced the plate with the updated, creaks less times but still creaks 2-3 times when turning lock to lock... drives me crazy
Old Apr 12, 2013 | 03:16 PM
cb1234's Avatar
2007 E-350
Cracking noise in Steering
Did it come with new hardware? Was it easy in terms of not messing with the RACK itself. I suspect it is not the plate but the nuts and bolts rubbing againt the mounting braket. There was a similar issue with the seats inside the some of these cars which was resolved by just changing the bolts.
Old Apr 12, 2013 | 04:01 PM
cb1234's Avatar
2007 E-350
Cracking noise from Rack mounting plate
how about taking out the bolts and nuts and greasing the hell of out them and reinstalling?
Old Apr 12, 2013 | 04:29 PM
VII's Avatar
VII
The part # only includes the plate.
Not sure if it is the bolts, I've been meaning to get under the car and have someone rotate the steering wheel to identify where exactly the noise is generated.
Post back if you find out!
Old Apr 12, 2013 | 07:24 PM
cb1234's Avatar
2007 E-350
I actually did that and used a stethoscope and the noise came from the plate under the RACK. The rack exerts a lot of lateral force on the plate and if it move a fraction of milimeter, it could potentially rub against the bolt and nut and here you go with irritating noise. It is just a theory.
keep me in the loop!!
