E-Class (W211) 2003-2009
OBD2 codes 674 and 671
Old Sep 24, 2012 | 11:29 PM
DBF's Avatar
DBF
2006 E320 CDI
My 06 W211 CDI has check engine light with codes 674 and 671. These codes are not in my code book. Just before CEL, the glow plug indicator light remained on after starting. Any ideas?
Old Sep 25, 2012 | 07:24 PM
DBF's Avatar
DBF
2006 E320 CDI
No, it stayed on for a while, then went out after CEL came on. I reset CEL yesterday. This afternoon, the glow plug indicator stayed on for about 1 minute after starting the engine. Then it went out. The CEL has remained off for about 1 1/2 hrs.
Old Sep 25, 2012 | 07:47 PM
DBF's Avatar
DBF
2006 E320 CDI
Old Sep 25, 2012 | 08:37 PM
ozusa's Avatar
2004 E320 4matic Sedan
The code translations are....
P0671, Glow plug, cylinder 1 - circuit malfunction
and, you guessed it,
P0674, Glow plug, cylinder 4 - circuit malfunction
Old Sep 25, 2012 | 08:49 PM
ozusa's Avatar
You may need to replace the glow plug control module...
the codes point towards the glow plug control module needing replacement (perhaps). I think a new module is less than $150, plus labor. It should not be a difficult job as it's fairly good accessibility. The glow plugs themselves are circa $15 each, if needed. I don't know the part numbers.
Old Sep 25, 2012 | 08:53 PM
DBF's Avatar
DBF
2006 E320 CDI
I appreciate the information. I thought it might be tied to the glow plugs and/or control. THANKS!
