E-Class (W211) 2003-2009
Trim panel help
Old Oct 14, 2012 | 02:20 PM
haris12's Avatar
E320
Trim panel help
Hey guys, my truck is getting some water inside. I came in conclusion that water is coming trough Trim panel that comes off where licence plate is attached. After looking more into it i noticed that clips that hold trim panel are not holding it tight. My question is does anyone knows where can i get those clips ? i am searching on parts.com but not having much luck
Old Oct 14, 2012 | 02:39 PM
konigstiger's Avatar
'71 Pinto
Not available separately check here to see if you can find matching fastener http://www.clipsandfasteners.com/Mer...ners_s/225.htm
Old Oct 14, 2012 | 03:06 PM
haris12's Avatar
E320
then would you say i need to buy whole panel?
Old Oct 14, 2012 | 04:50 PM
'71 Pinto
To the best of my knowledge, yes. But check with your local MB parts counter they be cooperative to help identify and acquire fastener.
Old Oct 14, 2012 | 06:27 PM
vettdvr's Avatar
03 E500 and Corvette
How do I remove the trim panel on DS door jam where the seat belts hits and has worn a hole?
