E-Class (W211) 2003-2009
PLEASE HELP --- I'M STRANDED RIGHT NOW
Old Oct 30, 2012 | 01:06 AM
700horses's Avatar
(The car is a 2007 Benz e350)
My key and fob are not working, it won't lock/unlock the doors, nor is it recognized by the ignition, so I cannot start the car.
I just replaced the batteries in the fob.
What else can I do??
Anyone???
Old Oct 30, 2012 | 01:02 PM
theunderlord's Avatar
(SOLD) 05 E55 Estate. 11 Golf TDi
is the car dead?
Old Oct 30, 2012 | 10:34 PM
700horses's Avatar
Not dead
No the car is definitely not dead, all of the lights work, I can even turn the stereo on.
I cannot even crank the ignition, its as if I were inserting a key from a different Benz... it goes in the hole, but does not make the little noise and unlock the ignition so I can turn the key.
Old Oct 30, 2012 | 10:45 PM
Ouch. Tow it to a dealer? D you have more that one key?
Old Nov 1, 2012 | 12:01 AM
700horses's Avatar
No spare
All of the technicians I spoke with said the first thing they would do is try a different key, so before I tow it I want to try that.
I ordered a new key from the dealer yesterday, hopefully it will arrive tomorrow.
Old Nov 1, 2012 | 10:50 AM
TMAllison's Avatar
09' E320
The first thing the tech should do is confirm you have a battery with 13V.......just because some lights light up does not mean there is sufficient voltage to crank the starter.....
Old Nov 1, 2012 | 11:35 AM
09W211's Avatar
2009 W211 E350 AMG Sport PKG
I heard about this problem from the dealer prior to purchasing my 2009 E350. The finance girl said it has been a problem for MB's with keys like ours.
Here's what I've been told. If the car isn't recognizing either key then that unit has to be replaced and it's north of a $1500 to replace that unit.
Hopefully this isn't the problem with your W211. Good luck!
Old Nov 1, 2012 | 12:29 PM
700horses's Avatar
Unit?
Thanks for chiming in.
What do you mean by "unit"?
Which "unit" would I need to replace? The EIS?
Old Nov 1, 2012 | 01:10 PM
09W211's Avatar
I wish I could be of more help to you sir, but unfortunately, I don't know what that "unit" is called. IIRC, I think the finance girl that it had something to do with the NAVI unit as well. Again, I could be entirely wrong.
Old Nov 1, 2012 | 01:55 PM
700horses's Avatar
Starter
Hmm thanks, I guess time will tell when the new key arrives.
Also, TMAllison thanks for chiming in as well, I didn't notice your reply earlier (checking this with my phone). What you said makes complete sense, but would that apply in this situation? The starter doesn't seem like it has a chance to be engaged at all since the ignition doesn't turn at all, the key is not recognized; Could a flat battery be causing this too?
Old Nov 2, 2012 | 08:19 AM
BavarianPride's Avatar
2013 E350
You could try this procedure I read somewhere in the past, :
1
Insert the key into the ignition.
2
Press and hold the "LOCK" button on the key fob.
Remove the key from the ignition. Keep the "LOCK" button held down while removing it.
4
Press and release the "UNLOCK" button five times.
5
Release the "LOCK" button. The fob should be reset.
T.
Old Nov 3, 2012 | 06:05 PM
700horses's Avatar
Reset
Thanks a lot for the advice BavarianPride, I tried that and sadly it didn't work. I did notice a crack on the rubber part of the unlock button of the fob. It looks like it was worn away from being pressed a million times; Perhaps moisture got in there and short circuited the circuit board?
I'm still waiting for a new key... It should have been here already, but due to hurricane Sandy, apparently all the shipments from the east coast are delayed!
Old Nov 4, 2012 | 08:35 AM
mrcooley's Avatar
11 ML350W4, 07 E550W4
If the key doesn't work - tow it to the nearest dealer.
A couple possibilities - bad shifter or bad EIS. Most likely the EIS. Good luck. The SDS at the dealer will narrow it down.
Old Nov 5, 2012 | 02:34 PM
700horses's Avatar
New key works! - Thanks everyone.
So the new key came in today, I didn't have to sync it, program it or anything... Everything worked out the box just like it should!!
Thanks for all the advice everyone!
Old Nov 5, 2012 | 02:35 PM
mrcooley's Avatar
Just remember - if you lose that key you will be in the same spot. Make sure to order another.
Old Nov 5, 2012 | 02:41 PM
700horses's Avatar
Yes great reminder! I actually already ordered a second key!
