E-Class (W211) 2003-2009
Fog lights HID conversion?? (need help)
Old 11-12-2012, 04:09 PM
700horses's Avatar
2007 e350
I want to upgrade the halogen fog lights to match the HID headlights (which are aftermarket Philips 4300k 85122 35w D2S)
I believe the fogs are H11, can I upgrade these to D2S or will that be too hot?
Otherwise which bulb will match the 85122??
Anyone???
The car is a 2007 e350 (factory AMG kit package).
Old 11-12-2012, 05:33 PM
700horses's Avatar
2007 e350
Optimal size
Or would it be better to convert the fogs to H9 or 9006??
What is the best fog light HID kit for the AMG bumper in the w211?
Old 11-12-2012, 05:55 PM
desired_speeds's Avatar
2007 SL55 AMG
get a set of 5000k H11 HID kit for the foglights and you're good to go.
Old 11-12-2012, 07:47 PM
700horses's Avatar
2007 e350
Thanks!
So 5000k H11 will match the color of the Philips 85112?
Any specific brand of bulb I should look for?
I also read that the PIAA Extreme White Plus match..?
Any thoughts?
Old 11-14-2012, 11:16 AM
2.7Tallroader's Avatar
W211
The 5000K are a tad whiter than the 4300K. I changed mine out to H11 5000K as I also changed out my headlights to 5000K. If you want them to match, get the same color temperature.
Old 04-07-2013, 07:01 PM
westu93's Avatar
'04 E55 AMG
I am looking to install some 8000k for my fog lights, to match my 8000k in the city lights. But how did you learn to install your fog lights? Do you have a link you used?
Old 04-07-2013, 10:37 PM
AMGAffalterbach's Avatar
2014 BMW M235i
If you search the forum on this westu93, you can find information on that install. Welcome to the forum by the way. The simplest way to do so is to get a kit from DDM tuning that will allow you to do foglight with the slim ballast. They won't be very effective fog lights at 8000k though, but I hate the blue and yellow look ricers have for headlights and foglights, respectively.
Old 04-08-2013, 12:03 AM
W211
I've used the DDM HID kits quite a bit, but on the cars with CANBUS, I would rather use a kit that is already CANBUS ready. It is normally the original size ballasts (not the smaller ones), but it does away with the error eliminators. Even if you use the slim ballasts that DDM has, you'll need an error eliminator and their ballasts has another small box in the output side. So there are three things (Ballast, Error Eliminator, and small output box) you'll need to find places to mount them to.
The last ones I used were CANBUS ballasts, so that was the only thing to mount. On the W211, you'll have to make a hole in the fog light cover to accomodate the wires going in and out of the foglight housing. It's better to make it a bit smaller that it being too large to make a good watertight seal.
Old 04-08-2013, 01:51 AM
westu93's Avatar
'04 E55 AMG
What do you think is the best light to match 8000k? And do you think it is possible to just change the bulb and not install a whole kit. I just want to do it for the looks because i never use fog lights where i live, especially for my w211 the fog lights have to manually turned on.
Old 04-08-2013, 02:11 AM
2014 BMW M235i
I'm not sure if there is any normal incandescent bulb that is close to 8000k. That's very blue, I've only seen bulbs that match up to 5000ks. They might exist but I haven't found any. If you're going to be going for strictly aesthetics for you fog lights (a little bit of a ricer thing to do though), look for error-free LED bulbs that will match 8000k. I know they're at least available for the city/parking lights in the front inner headlight cluster. eBay might be a good place to start.
Old 04-08-2013, 04:46 AM
westu93's Avatar
'04 E55 AMG
I see what you mean, maybe i should just look into getting an HID kit than. I actually have 8000k for my city lights but i might just change them to 5000k because they are noticeably bluer than the headlights. What degree did you use for your city lights and fog lights?
Old 04-08-2013, 03:34 PM
2014 BMW M235i
I'm going to 5000k all around. 55w balasts for the lowbeams, phillips bulbs for the high beams, LEDs for the city lights. Fog lights I'm still deciding but probably won't go HID yet.
Old 04-09-2013, 02:38 PM
btv94's Avatar
2007 E350 RWD SP1 (M211.056/E272.964)
I just installed 8000k DDM HID Kit With Slim Ballast - 35W two weeks ago and it works great.
$29 for HID kit and $15 for Error Eliminator BOW3.
Old 04-17-2013, 06:24 PM
Nero Tenebre's Avatar
W209 CLK Renntech Widebody, C140 CL600 V12, AP2 S2000, NSX Twin Turbo, R8 V10
How can you tell if your car needs CANBUS kits? Looking for an error free HID kit for my fog lights if a 35W system won't break my lenses or melt my housings, or perhaps doing LED if I can get one with capacitors.
Old 05-03-2013, 11:05 PM
fartpimpson's Avatar
'07 E550 - current ; '11 Ducati 848 Evo - SOLD ; '07 BMW 335i - SOLD ; '99 BMW M3 - SOLD
I just installed a set of error free H11 6000K hid kit for my 2007 E550 today. I also disabled the directional fog light up feature so my fog light won't turn on when I steer right or left. =)
Old 05-04-2013, 03:27 PM
2014 BMW M235i
There's a directional fog light feature on the 2007 E550? Are you in the US?
Old 05-04-2013, 05:34 PM
Yes I am in US.
Old 05-04-2013, 06:46 PM
2014 BMW M235i
What is this directional fog light feature?
Old 05-04-2013, 09:20 PM
Critter's Avatar
07 E63 + 07 CLK63CAB
This feature turns on the appropriate fog light when the wheel is turned and I think signal on to give you the advantage of a little more light for the direction you are going to be travelling. Ie, turn wheel left, left fog light is illuminated this is only operational when the headlights are on. My lights are always in Auto mode so this might also need to be selected to get this function to work.
Old 05-06-2013, 01:14 PM
My lights are in auto mode. After installed HID fog lights, I asked my technician to turn this feature off so my fog light won't flicker when it's dimming.
Old 05-27-2013, 07:53 PM
2014 BMW M235i
Sorry to bring up this thread again but I have a 2007 E550 as well and I never noticed this feature before... how do I turn this off?
Old 05-29-2013, 03:05 PM
Craftysince86's Avatar
W211
just use the manual on n off?
edit: nvm i thought you were asking something else
Old 05-29-2013, 09:24 PM
2014 BMW M235i
Is this something in the instrument cluster menu or via STAR diagnostics
Old 05-29-2013, 10:29 PM
mank1970rr's Avatar
cghjmkik
Old 06-04-2013, 02:06 PM
City Rat's Avatar
Currently: 2019 E450 AWD, Previous: 2002 CLK55 Cab
Guys, normally sorry to revive an old thread but since this is timely for me I thought I would anyway, lol. Looking to upgrade the brightness of the beam from my foglights. Given the price of a new kit:
http://www.google.com/imgres?imgurl=...ed=0CC4QrQMwAQ
I thought that I would first try to better results by replacing the bulbs with something brighter. What is the size or part number of the replacement foglight bulbs, D2S 35W?
Additionally after reading this thread I am now very clear that I will want all of my lights:
1-to match in color, white, not blue or yellow
2-not LED
Therefore what are the brightest bulbs that I can get for my CLK which won't burn out my wiring, won't burn out housings and lenses and will give me more of a fighting chance at seeing critters large and small that like to jump out onto rural roads at night. Thanks.
Quick Reply: Fog lights HID conversion?? (need help)
