E-Class (W211) 2003-2009
W211 hood hinge replacement
Old Nov 20, 2012 | 03:27 PM
enochbell's Avatar
2004 E500 Wagon
I need to replace the hinges on the hood of a 2004 E500 Wagon. Has anyone done this? Can it be done as a one-person operation? The hinges are an easy plug and play, but I think I might have to suspend the hood to make the swap. Any advice would really be appreciated.
Thanks,
Greg in Atlanta
Old Nov 20, 2012 | 03:42 PM
konigstiger's Avatar
'71 Pinto
Ideally you should remove hood - check your PM.
Old Nov 20, 2012 | 04:07 PM
PelicanParts.com's Avatar
SPONSOR
I'd grab a buddy to help you out in removing the hood.
Old Nov 21, 2012 | 01:41 PM
enochbell's Avatar
2004 E500 Wagon
Thanks, I am looking forward to instructions sheet. If I can do it one side at a time I can get my son to hold it vertical...depending on how much it weighs. Anybody know approximate weight? My only other experience with Mercedes hood is my 230sl, which weighs no more than 15 pounds... wish this one was aluminum as well!
Old Nov 21, 2012 | 04:50 PM
SPONSOR
35-40lbs maybe?
Old Nov 23, 2012 | 07:16 AM
enochbell's Avatar
2004 E500 Wagon
closure
Thanks for the advice and instructions, PelicanParts. Did this job yesterday with no drama. Got my daughter to help support the hood while I swapped out the hinges, one side at a time. Hood required no more than 10 pounds of lift.
Thanks!
g
