E-Class (W211) 2003-2009
Headlight washers not coming on
Old Nov 21, 2012 | 08:22 PM
Gripenfelter's Avatar
E500 4matic
I have a 2004 W211 E500 4matic. I have the washer button beside the headlight knob. With the car on and lights on the washer button does nothing. Where is the fuse for the system located? Anything else to check? Is this a common problem?
Old Nov 21, 2012 | 09:09 PM
HotBenthust's Avatar
2004 E320
This is a common issue to some car owners.
You can refer to your manual button if you have.
Some manual says, the headlight washers can only be activated after various windshield wipes with lights on.
Check first your manual and if it says something like this, try it and hope this time it will work.
Old Nov 21, 2012 | 11:33 PM
Barry45RPM's Avatar
2015 ML 350
Also... if you haven't used them in a while, all the fluid in all the lines evaporates and you must press and repress the button over & over to prime the lines again. Then they will work on demand.
There's a lot of empty hose leading up to the headlight washer nozzles.
Old Nov 22, 2012 | 01:54 AM
xxGenericSNxx's Avatar
99 ML430, 01 CLK55, 07 R63, 15 E63 Wagon
On my 01 CLK, one time I pressed the button too many times and the hose came loose from the connection to the washer itself. You might want to check to make sure the hoses are all secured.
Old Nov 22, 2012 | 09:59 AM
E500 4matic
Alright thanks. I'll take a look at the hoses. No fluid on the driveway so I dunno.
Old Nov 23, 2012 | 02:12 PM
E500 4matic
Still nothing. Where would the fuse be?
Old Nov 26, 2012 | 11:48 PM
AMGAffalterbach's Avatar
2014 BMW M235i
Have you checked your headlight fluid and blinker fluid?
Old Nov 27, 2012 | 10:03 AM
E500 4matic
I'm thinking maybe a power line fell off the flux capacitor.
Old Nov 28, 2012 | 11:28 PM
2014 BMW M235i
Good guess but it's usually the inertial dampeners that haven't been properly serviced that will cause this issue. =P
You end up fixing it or did you have to take it in?
