E-Class (W211) 2003-2009
HID Questions
Old Nov 25, 2012 | 03:12 PM
benzfever16's Avatar
E-320
HID Questions
Whats up guys my low bean bulb burned out and i was thinking i cna go with hids 6000k can i just buy a 6000k bulb and put it in there or do i need other parts too i do not know much about hid's i would appreciate some help thank you
Old Nov 25, 2012 | 04:58 PM
NBDT's Avatar
2004 E500 (W211)
If your E320 was equipped with OEM HID headlights, then a replacement HID bulb is the easiest and safest way to go.
If it's not equipped with OEM HIDs, then a plug-and-play kit would suffice - notwithstanding the other forum voices regarding light splatter pattern. Should you choose to upgrade with a HID kit then theretrofitsource.com H7 Morimoto Elite system is a good plug-and-play option.
Of course, a complete retrofit would be the best, but is not cost effective for some. Either way, you'll find good options and information about HIDs at the Web site.
Old Nov 25, 2012 | 05:55 PM
E-320
How can I know if I have oenophile hid do I haven't taken the bulb out yet
Old Nov 25, 2012 | 08:35 PM
NBDT's Avatar
2004 E500 (W211)
You should have a marking HID-D2S either Phillips or Osram near the base of the bulb or housing plus you'll have a ballast control or headlight control unit if you have OEM HIDs. An HID bulb (OEM or aftermarket looks vastly different from a traditional halogen), it won't look anything like your highbeam bulb.
