SunGlass Drawer stuck
Hi i was wondering if anyone know how to take out the sunglass drawer out. My sunglass drawer got stuck with coins and now i cant open it.
Thanks in Advanced
2008 E350
Thanks in Advanced
2008 E350
Received 4,435 Likes
'71 Pinto
PM email address I will forward instruction sheet illustrating part details to assist in releasing catch hooks for drawer removal.
I am sure Konigstiger's instructions are far better, but I just (very gently) stuck a very thin flat-bladed screwdriver into the opening at the top of the drawer, and it popped open.
C320 CDI Estate, E500 4M Wagon
Did you guys figure this out? I just had the entire glove box out...this is probably the only way to get at that drawer mechanism.
Let me know if you need the play-by-play.
Smash
Smash
Nothing was wrong with the drawer on mine; I had the glovebox out to get at other areas, and noticed that the entire right side comes off as part of the "glovebox", drawer included.
I ended up removing the entire dash as well (only a few extra bolts, lol).
Anyhow, if anyone needs help or has questions on access to this area, let me know.
Smash
Smash
03 E500 and Corvette
![naughty](https://mbworld.org/forums/images/smilies/naughty.gif)
2017 991.2 Turbo PDK 2017 C63S Coupe Ceramic Brakes 2015 CLS63S AMG Full House
He only way I know to get at the mechanism is with the entire right front glovebox/panel off. You could try remove just the HVAC controls and pry it loose from the side, but you might damage it. Either way,
1. Remove wood trim by removing right side dash end cap, then pry out towards the interior of the car to release 2 fasteners above the key. Then wood strip slides 1 inch right and is released.
2. Pull up at 10 & 2 positions with a prying tool to release the center speaker grill (models after 2004), remove all 20mm Torx and the HVAC will come out.
You'll see the drawer on the right - but there is not much room to do anything.
If it really bugs you and you want to remove the entire right GB/panel, post back and I'll write you the instructions.
HTH,
Smash
HTH,
Smash
