E-Class (W211) 2003-2009
Old Jun 17, 2015, 07:29 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:Browse all: Steering and Suspension Guides
Print Wikipost
04 E500 rear shock absorber part#
Old Dec 1, 2012 | 01:09 AM
joe88's Avatar
2004 E500
Hi, I Just joint MBworld, need help on rear shock absorber part#, my e500 making a clunking noise from rear, I'm pretty sure it's shock absorber problem. I came acroess two different part# fits 04 E500, it's the bilstein W0133-1910549 and W0133-1910550 fit different chassis, which one I should use... thanks in advance!!
PS: VIN# WDBUF70J94A603013 doen't know which part# it belong!
Old Dec 1, 2012 | 09:46 AM
konigstiger's Avatar
'71 Pinto
MB part # 2113262800 / Bilstein W0133-1910550
Old Dec 1, 2012 | 09:36 PM
joe88's Avatar
2004 E500
thanks for reply, unfortunately I discovered a new problem today, the rear driver side was lower than the other three corner (about an inch).."what happen to this car" ...so my question is that has to be the air spring or just airline that leaks the air.....pls. help..!!!!
Old Dec 3, 2012 | 08:48 AM
vettdvr's Avatar
03 E500 and Corvette
You probably have a leak in the air spring. You can use OEM parts ($$$$$) or use the new Arontt's springs that may give a tad firmer ride and save lots of $$ and time.
Old Dec 4, 2012 | 07:12 PM
joe88's Avatar
2004 E500
I just had the car check in local indy shop, the RD's air spring and the tube between air spring and reservoir are in perfect condition (very clean), they told me the RD shock absorber (no oil leak and clean)didn't extend it was in compress condition that is why the RD is alway lower than other three corner, is it possiable???? I though air spring is the one which to adjust the high.......any comments !!! thanks
Old Feb 15, 2013 | 06:21 PM
thaituacs's Avatar
cls550
My car have same prolem, any help..thanks
