E-Class (W211) 2003-2009
Unable to reset the analog clock in my E500 2006
Old Dec 11, 2012 | 09:25 PM
vsv2020's Avatar
E500; ML320
Hi,
I need help to reset the Analog clock in my E500 4matic year 2006. It was working fine till few days ago and stopped working after service "C" done.
I attempted to reset with steering wheel control as well as Command center, but no help.
When I attempt with Steering Wheel control
Display says "Sync Off" time says 10:21AM , with
+ and - I change it to current time "say" 2:15PM
to confirm the time change as soon as I press "Reset knob" time change to original 10:21AM
if I attemt to change time from "Command Center"
with "sync on" the clock will change to correct time
"Say 2:15PM" but it will just stopped at that time
and will not "Stay On"
Tried several times but no Help.
Will Somebody Help me out here?
Old Dec 12, 2012 | 11:40 AM
RA72825's Avatar
Appears that you are setting the clock correctly, however it seems to have just died on you and refusing to run.
Old Dec 12, 2012 | 02:10 PM
vsv2020's Avatar
E500; ML320
Thanks,
Can I just change the CLOCK or do I have to change the Whole Instrument Panel?
Old Dec 12, 2012 | 04:35 PM
homeofstone's Avatar
2011 E63, 2011 Hyundai Genesis 4.6 v8, 2013 GMC Denali XL, 1965 Ford Mustang, 2005 Merc. E500
Check your manual and make sure you are not skiping a step for doing the reser. Also, sync it with the nav system and change the time using the nav command system. If is a cloudy day or in a building then the command system will not sync until it links with GPS sat. When I reset mine it took about 20 minutes before it would sync correctly.
Old Dec 13, 2012 | 10:57 AM
RA72825's Avatar
He synced it with COMMAND and it reset to the correct time if you read his post. It just doesn't run. I don't know anything about changing out the clock.Perhaps there is a hard reset you can do by disconnecting the battery(s). It is strange that the clock will actually reset to the correct time and then not run.
Old Dec 16, 2012 | 08:13 AM
vsv2020's Avatar
E500; ML320
Hi,
It started working correct time now.
I took out Navigation DVD from the trunk. Sync mode off, play around the time several times. and was able to adjust the clock to correct time. after 24 hrs or so reinserted the Navigation dvd. Now clock stays to correct time.
Old Dec 16, 2012 | 03:46 PM
RA72825's Avatar
good to hear!
Old Apr 18, 2014 | 07:59 PM
radoncdoc's Avatar
2004 E 55
same problem
I have the same problem but on an 04 E55 after dead battery. Not sure why removing NAV DVD woulkd do anything but I will give it a try
Old Nov 13, 2019 | 08:17 AM
phat's Avatar
mercedes 400e
My clock on 2005 E500 will always go back to 12 o'clock when i push the R (reset button) to confirm as instructed. Anyone can help
Old Nov 19, 2019 | 12:10 AM
ArtieK88's Avatar
S550
Same issue on my 2007 S550 but just found solution on another thread! Push button to first on position (no ignition) and within 1 minutes reset the command time. For me this then caused the analog clock to move. Poster had said something about beating the GPS connection so can also do in a garage. I didn’t mess with date so it may be off as others said it reset to 2003. Others spoke of some new software update helping. Hope it works for you.
Old Nov 19, 2019 | 05:14 AM
phat's Avatar
mercedes 400e
Thank you so much. Will let you know the outcome.
Good day
