E-Class (W211) 2003-2009
e320 tire question
Old Jan 13, 2013 | 04:48 PM
trimix's Avatar
sl600/Kleemann-ecu:tcu- 2015 E250CDI -Navion MB Sprinter
e320 tire question
I have a 2005 e320cdi and was wonder if i could put a stock set of 18" amg wheels on the car that i am taking off my 2006 sl600?
fronts are 255/40/18
Rears are 285/35/18
Old Jan 13, 2013 | 06:40 PM
AMGAffalterbach's Avatar
2014 BMW M235i
18s will fit on the car, and the width should be okay if you aren't lowered or anything. 285 should work but I am not sure if you will need any spacers. 255 will definitely work in the front if it is on an 8.5" wheel as that is what I am running on my E550 4-Matic all around right now.
Make sure the offsets are the same it should be a 5x112 bolt pattern and somewhere in the 30mm range for offset. A tire shop could give you all those details.
Old Jan 14, 2013 | 05:10 PM
trimix's Avatar
Great thank you for the reply. I will look into it.
Trimix
Old Jan 14, 2013 | 06:55 PM
2014 BMW M235i
For sure man, good luck.
