"Check Oil Level at Next Refueling"
![Question](https://mbworld.org/forums/images/icons/icon5.gif)
Hi all,
While coming back from a long trip (400 or so miles) I had this message pop up on the display for a few seconds then go away. Is this anything to worry about? Or is it just a trivial ordeal. I just got the oil changed a week ago.
![crazy](https://mbworld.org/forums/images/smilies/crazy.gif)
e220 cdi w211
I think this might help
https://mbworld.org/forums/e-class-w...nsumption.html
Check your oil level on the next morning before you start the car (make sure it is leveled). Sometimes it happens on long trips, especially if you push a bit too much, that a lot of oil is consumed. And you have a thirsty engine, both for oil and gas.
2004 E320 4matic Sedan
I got a similar, but not identical, message this weekend
I have an E320. The message I received this week-end was "Add one quart of oil at next refueling" or words like that. So that's just exactly what I did. It is not pumping smoke out the back, so I suspect when the last oil change was done, in September by my MB dealer, they did not put in any more than commercial prudence and their cost-accountant requires.
I received this message once last year also. So I did what it said, then, too.
Sometimes we over-think these cars' labor-saving features. Just do what it says, and no one will get hurt.
It takes almost 8 quarts for my E500. On one oil change that I did not do myself they only put in 7 quarts and I got the message about a month later. Also make sure that only oil approved by Mercedes is used.
