Why Change Spark Plugs at 5 years?
Air filters are different though and would fall under the engine oil/filter category of preventative maintenance.
The boot sure fits snug, creating a good seal in the plug "silo"... I under if that would trap any spin-off from burning anti-seize compounds? Anyhow, I read this post top to bottom first, and decided to follow the recommendations. We'll see how things go next time I have to replace the plugs.
Bosch YR7MPP33, which is exactly what came out. Ordered them online Sunday evening, they were waiting for me, on my doorstep, Tuesday afternoon... $44.52, after tax, title, and license... $54.07 delivered.
The 2003 plug interval is 100k as per MB. That is why I used the original plugs again. I may only go about 60k on these plugs because of the age of the engine now. 130.500 miles
By the way anti seize material just ensures that the plug will not damage the aluminum threads when removed, steel plug and aluminum head, once you pull threads the first time, you will change your ways quickly.
It keeps the metals from bonding and seizing, but also causes over tightening is used with "dry" thread specifications.
The threads of good plugs are (or should be) plated to prevent seizing without lubrication.
Since most seem to have no problem removing the plugs, I am guessing MB specs plugs well matched to the head material.
On Fiats, I would never install a plug without anti-seize, but tightened them "gently".
You would be surprised how easy it is to over torque a bolt (or sparkplug) with lubed threads. "Just say'n . . . . . "
