Click sound when braking
2007 E350 4matic
So it was bound to happen...I hit a big ol' pothole a couple of weeks ago where I thought my car was going to just fall apart on the spot. But it didn't, the car is still in one piece and I haven't noticed any issues like pulling, alignment problems and wheel balance issues. In fact the car drives just as well as it before hitting the pothole.
Except that...since then when I brake I hear a click coming from the driver's side front wheel area. Kind of sounds like maybe a bushing got damaged or something became slightly loose.
It doesn't sound like a bearing issue. It does not happen when turning, accelerating or otherwise driving. Only when I hit the brake after the car has been standing still like when parked overnight, or parked during the day when I'm at work. Then through the rest of my commute, not a sound.
I know the best thing is to put the car up on a lift and take a look but I just haven't the time with being busy with work and school.
Any thoughts on what could have been damaged? Could it be the ball joint? It doesn't seem like anything was broken but something was definitely damaged.
Thanks as usual in advance for your thoughts and advice.
03 E500 and Corvette
IF the clicking is front wheel and when braking it won't be a suspension part but you might have broken a race on the wheel bearing or cracked a roller. If this did happen check it asap as a failure of this type might cause the wheel to come off the car.
![](https://mbworld.org/forums/images/ranks/veteran_army.png)
![EEK!](https://mbworld.org/forums/images/smilies/eek.gif)
2007 E350 4matic
I've had my tires replaced since I originally posted about the issue and asked the tech to give the suspension a once over.
I don't think I've heard a peep (other than my brakes) since then. The car drives fine (jinx). Better actually since I got new tires. No vibration or shimmy anywhere that I can tell and I've taken it past the speed limit a couple of times.
I'm due for an inspection soon so I'll have them take another look but otherwise haven't had the issue again.
